RichardAllsopp
Message 1 of 3
Re: port forwarding bt hub 3 via homeplugs
Hi I have set up portforwarding on my router and says open on my Xbox one but when I do online check it's says closed wich is giveing me lag on games like (fifa 14) I have tryed everything but there is 1 more thing I think may be causeing it I use homeplugs and they are connected through 1 main source I was wondering do you have to portforward the homeplugs and always use ip adress
2 REPLIES 2
ItsChip
Message 2 of 3
To this date, I've never seen a game which requires ports to be open.
Let me explain briefly how port forwarding works:
  • After defining a port-forwarding rule, this tells your router which device to send incoming packets on those port(s)
  • You would only need to set up a rule if an external service needed to connect to an application via that port when there was no ongoing connection
  • Games do not require ports to be forwarded because they open connections to the multiplayer servers/voice servers and all communication between the game and the external server is via that connection
  • If a service required port forwarding, it would not 'lag' without it, it would simply not work. The data could not be passed to the service if it was a requirement.
If you are indeed experiencing lag due to a poor internet connection to your Xbox, follow these steps:
  • Restart your Home Hub and check if the connection improves
  • Ensure your Homeplugs are not connected to extensions, they are connected to wall sockets
  • Ensure the cable going between your Hub and the Homeplug is connected to the 'GBit' port on the Hub (should improve bandwidth)
  • Remove any port forwarding rules you have made in an attempt to fix this issue
  • If possible, try using a wireless connection or try wiring the Xbox directly to the router
If the connection issues occur across multiple devices, please provide details.
Thanks!
    To say thanks for this post, please click the star on the left
   If not, please accept my apologies, hope I can help next time
RichardAllsopp
Message 3 of 3
.so if my Nat was moderate I would not lag and is it best to use upnp and remove all portforwarding I have set up
