tonypeaker
Message 1 of 2
Re: reoccurring broadband fault
Have exactly the same problem
but now unless there are at least 5 drop outs during a day they wont even raise it as a fault
the best they do is monitor the line for 24hrs which means if its a sunny day
they class it as being fixed
not impressed
1 REPLY 1
imjolly
Message 2 of 2
I moved your post to start own thread
can you give more information and also your adsl stats
are you using the test socket with a new filter
try quiet line test. Dial 17070 option 2. Should be quiet andbest with corded phone
