Message 1 of 9
Re-set broadband talk
The BB talk number has dropped again, so Im trying to reset it by the usual route...............
For the last two hours there has been an internal system error, and I cant do the reset..anyone else having this issue tonight, or recently?
AQ.
"Welcome to Royston Vasey - You'll never leave."
8 REPLIES 8
Message 2 of 9
Re: Re-set broadband talk
my BT talk still seems to be working ok
Distinguished Guru
Message 3 of 9
My 'sipdroid'talk number calls my home phone numberSmiley Wink
(do ya think 'they' are looking at blocking it....?)
-+-No longer a forum member-+-
Message 4 of 9
Nooooooooooo, but funny thing is all the lights are on, on the hub, cant ring in or out on BBTalk and getting equipment switched off or unavailable.........
First time I've been unable to perform a fix..........Smiley Sad
AQ.
Distinguished Guru
Message 5 of 9
Are you using the hub2 or the hub3?
hub2 - Is this via a hub phone or the mobile?
          What happens if you plug a standard corded phone in to the hub and use BBT - owt or nowt
hub3 - hmm, calling my BBT number from my landline and the landline tone has gone very very weirdSmiley Surprised
Message 6 of 9
Hub 1 Bband talk locked down well and good.
AQ.
Distinguished Guru
Message 7 of 9
Whoops, silly me. I'd completely forgot that you're using old faithful.
One for the mods me thinks - they'll find out what's gone wrong and put it right, won't they....?
Message 8 of 9
Could be a simple password lock after x attempts to access failed. Ill try later and report back.
AQ.
Message 9 of 9
The 'internal system error' last night still had me locked out today.
Tried a password reset, it wouldnt accept 'btopenworld.com' as a valid email address, only 'btinternet.com'
Password reset, configure for BBTalk, all ok today with it.
AQ.
