Message 1 of 12
Re: very slow upload speed - POST MEANT FOR imjolly
I'm experiencing terrible upload speeds, which BT tell me is within their expected range ie 448kbps ...
However, in this post, you asked about 21CN and using the link to check it say it's enabled for my exchange ...
What does that actually mean eg does it mean there is a way to get a faster upload speed even though Open Reach only say P(lanned) A(era)?
FYI; the recent move from iPhoto to Photos and the associated need to upload my pghotos to iCloud to be able to sync them to my iPad is the root cause to my woes - do BT not "get" that the Cloud is here?
Many thanks ...
11 REPLIES 11
Message 2 of 12
enter your phone number and post results  remember to dlete number  https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 12
Can you work with this (I'm not sure how to grab a snapshot on an iMac and post it here)?
BT BROADBAND AVAILABILITY CHECKER
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+ Up to 5 -- 3 to 7.5 Available
WBC ADSL 2+ Annex M Up to 5 Up to 1 3 to 7.5 Available
ADSL Max Up to 4 -- 2.5 to 7 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings
Copper Multicast -- -- -- Available
Message 4 of 12
From the dslchecker results adsl2 is available with estimate of about 5mb conenction and upstream probably 0.8/1mb.  Can you post any router stats?
Message 5 of 12
from your earlier posts you were on adslmax which has a max upload of 448k
Message 6 of 12
I saw that john46 but I was just trying to make sure adslmax before asking for mod help
Message 7 of 12
I have a BT Home Hub 4, but I'm not sure how to get the router stats you're looking for?
Message 8 of 12
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Message 9 of 12
This is the latest entry I can find ...
12:27:34, 25 May. (435858.560000) DSL is up
12:27:33, 25 May. (435857.390000) DSL noise margin: 5.90 dB upstream, 6.10 dB downstream
12:27:32, 25 May. (435856.360000) DSL line rate: 1023 Kbps upstream, 7671 Kbps downstream
12:25:54, 25 May. (435758.730000) DSL is down after 14 minutes uptime
Message 10 of 12
you are on adsl2 with good 7.6mb down and 1m up
can you run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
