phonic
Message 11 of 87
Re: Read If you have Aluminium(even if length is 300m) and thinking of getting Infinity2
Just to add e-side is copper, d-side is Ali.
Bullitt
Distinguished Expert
Message 12 of 87
not any more
Webby
Message 13 of 87
The E-side is still copper for his phone line. And the D-side will be alu from the cab to his home.
Bullitt
Message 14 of 87
true but i doubt he's refferring to his phone
phonic
Message 15 of 87
I was reffering to your question on ADSL2+ that the goes to the exchange, not the fibre product that has only 5m tails going to the DSLAM CAB.
phonic
Message 16 of 87
Are you referring to FTTC or ADSL2 that the e-side is not copper?.
btw, from the box to the FTTC cab you still have copper tails of about 5m max.
Bullitt
Message 17 of 87
the eside on fttc is f(ibre)
phonic
Message 18 of 87
Yes it's fibre all the way to the exchange, and reason for the higher(well should be) speeds.
But saying that you will have about 2-5m copper tails to the new FTTC street CAB that sits next to it, as all lines go to the existing old cab, then to the FTTC CAB. but anyway, my point is it should be way better and more stable, it's not the case, as my 300m ALi is old and not in a good way....
Deathtrap3000
Recognised Expert
Message 19 of 87
If the fttc cabs right next to the old cab then its that short, but many fttc cabs have been placed as far as 50m from the old ones.
Bullitt
Message 20 of 87
how do you know its ali?
how do you know its old and not in a good way?
