dale0404
Message 1 of 10
Really high ping when using desktop and laptop at the same time.
Hi there everyone.  I have already reported this to the engineers and very helpful they were as well.
The problem.
When I use the desktop for online games I usually see a ping of between 30ms and 70ms depending which online game I am playing.
If one of my daughters goes on the laptop then my ping will increase (in game) from anywhere between 200ms and 15,000ms.  Yes I have seen the ping that high!
I am wondering if any of you beautiful people can provide an answer to this please?
I pinged bbc.co.uk while not using the wireless for the laptop and then my daughter accessing the internet (faceboook etc):
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data: Reply from 212.58.241.131: bytes=32 time=26ms TTL=241 Reply from 212.58.241.131: bytes=32 time=31ms TTL=241 Reply from 212.58.241.131: bytes=32 time=27ms TTL=241 Reply from 212.58.241.131: bytes=32 time=19ms TTL=241
Ping statistics for 212.58.241.131:     Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds:     Minimum = 19ms, Maximum = 31ms, Average = 25ms
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data: Reply from 212.58.241.131: bytes=32 time=288ms TTL=241 Reply from 212.58.241.131: bytes=32 time=203ms TTL=241 Reply from 212.58.241.131: bytes=32 time=233ms TTL=241 Reply from 212.58.241.131: bytes=32 time=178ms TTL=241
Ping statistics for 212.58.241.131:     Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds:     Minimum = 178ms, Maximum = 288ms, Average = 225ms
Also did a trace (this was when I played a youtube video @ 720p):
Tracing route to bbc.co.uk [212.58.241.131] over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  BTHomeHub.home [192.168.1.254]
 2   637 ms   447 ms   354 ms  217.47.14.58
 3   330 ms   408 ms   526 ms  217.47.14.161
4   393 ms   341 ms   381 ms  213.1.69.34
5   399 ms   347 ms   370 ms  217.41.169.179
6   396 ms   233 ms   271 ms  217.41.169.107
7   410 ms   651 ms   278 ms  acc1-10GigE-9-3-0.sf.21cn-ipp.bt.net [109.159.251.95]
8   174 ms   156 ms    84 ms  core1-te0-12-0-6.ealing.ukcore.bt.net [109.159.251.5]
9   259 ms   323 ms   378 ms  peer2-xe0-0-0.telehouse.ukcore.bt.net [109.159.254.102]
10    71 ms    59 ms    68 ms  194.74.65.42
11     *        *        *     Request timed out.
12     *        *        *     Request timed out.
13   294 ms   347 ms   333 ms  ae1.er01.thdow.bbc.co.uk [132.185.254.18]
14   302 ms   218 ms   198 ms  132.185.255.130
15   217 ms   213 ms   225 ms  212.58.241.131
Trace complete.
ADSL Line Status
Connection information
Line state:
Connected
Connection time:
3 days, 15:55:08
Downstream:
8,128 Kbps
Upstream:
448 Kbps
ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Fast
Noise margin (Down/Up):
13.5 dB / 29.0 dB
Line attenuation (Down/Up):
21.0 dB / 12.5 dB
Output power (Down/Up):
19.9 dBm / 11.9 dBm
FEC Events (Down/Up):
0 / 2
CRC Events (Down/Up):
182 / 29
When we first got the hub in January we could happily play games and watch videos at the same time.
Thank you in advance for you help.
Dale
9 REPLIES 9
Message 2 of 10
Re: Really high ping when using desktop and laptop at the same time.
If other user are using your Internet connection, then an increase in response time is normal and to be expected. It really depends on what the laptop was being used for.
Packets of data for gaming applications have no priority over other traffic. So your game data packet will have to wait its turn, when other people are using your Internet connection.
dale0404
Message 3 of 10
Yep, I understand that mate.
My point being is that when we first got the hub in January we could be on the desktop and the laptop at the same time doing whatever without any issues.
This has only been happening for the last few weeks so something is definately amiss.
Message 4 of 10
Perhaps the exchange capacity is reaching its maximum on your Virtual Path. What download speed does the BT Speedtester show?
I assume that the desktop is hard wired, and not using wireless?
dale0404
Message 5 of 10
Yes the desktop is wired.
Reults:
1. Best Effort Test: -provides background information.
 Download  Speed
 1.58 Mbps
0 Mbps7.15 Mbps Max Achievable Speed
Download speedachieved during the test was - 1.58 Mbps For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps. Additional Information: Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 7.15 Mbps
dale0404
Message 6 of 10
Would this have anything to do with the following?
ADSL Line Status
Line state:
Connected
Connection time:
3 days, 19:25:02
Downstream:
8,128 Kbps
Upstream:
448 Kbps
ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Fast
13.2 dB / 29.0 dB
21.0 dB / 12.5 dB
19.9 dBm / 11.9 dBm
0 / 2
189 / 29
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
HEC Errors (Down/Up):
205 / 13
Error Seconds (Local/Remote):
0 / 0
What about the latency type?  Should it be interleaved?  Also the noise should be somewhere around 6dB if I have read these forums correctly?  Also what about the HEC Errors?
Dale
Message 7 of 10
interleaving will increase latency fast is normally favoured by gamers your connection speed is the maximum for adslmax (up to 8mb service) a reduction in noise margin in your case would achieve nothing as you are already connecting at the maximum speed possible the HEC's are low for your connection time and nothing to worry about
your down load speed however is low was the speed test carried out on a wired device ?if yes could you try 3 speed tests at different times of day over the next 24 hours to see if exchange capacity is causing any problems
dale0404
Message 8 of 10
Will do.  First one should be sometime around lunchtime BST.
Message 9 of 10
It looks like bad exchange congestion to me, but do the different speed tests requested, and they sholud give the answer.
Message 10 of 10
my feeling Keith speed tests really to confirm
