Message 21 of 32
Re: Really slow broadband all of a sudden.
that noise on the line needs solving first phone BT Faults on 151 but do not mention broadband when you call once the fault is cleared your broadband should improve the speedtester has been playing up recently could you try speedtest.net as well
Message 22 of 32
if you used the test socket when you tried the quiet line test and heard the noisy line then you need to report a phone fault to 151 with no mention of broadband.  get rid of noise and help improve your connection.
btspeedtester is inconsistent at present - works and then doesn't and then gives wrong download speeds
Message 23 of 32
we don't have a test socket here, just some old BT box on the wall put there by the engineer last time he came. is it worth asking BT to get that upgraded? after all they put it there 🙂
Message 24 of 32
if there is a problem with noise on your line then if you get an engineer callout he may well replace the old master if it is causing the noise problem.
Message 25 of 32
you will get charged for that unless the socket is faulty at the openreach side of the connection just report the line fault then you may get it replaced then
Message 26 of 32
Quick update, rang BT again, they seem to think that there was a fault at the local exchange which is now fixed. Since they "fixed" the problem the router has remained on and connected and the speed has neither gone up nor has it stabilised, the only thing that has improved is the ping which has reduced from anywhere around 150 up to and over 1000.
Here is the latest ADSL status:
ADSL line status
Connection information
Line stateConnected
Connection time4 days, 0:24:14
Downstream6,912 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)18.4 dB / 21.0 dB
Line attenuation (Down/Up)21.0 dB / 11.0 dB
Output power (Down/Up)19.8 dBm / 12.5 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)124 / N/A
HEC Errors (Down/Up)N/A / 7
Error Seconds (Local)284
Speedtester is still not working for me but speedtest.net and the bbmax speedtest tool both give around 500kbps
Message 27 of 32
could you please run the bt speedtest as we need to see your ip profile which sounds like it is low from the speedtest results you posted the tester is still playing up but it is reporting profiles ok
Message 28 of 32
Didn't work for me this morning after numerous attempts
Message 29 of 32
Speedtester didnt work at all for me. Just said cannot run a speedtest for your broadband connection. Contact your broadband supplier.
Last worked for me last night and the IP profile was 6mbps if memory serves
Message 30 of 32
6mb profile wouls be about right for your connection speed.  btspeedtester is a waste of time just now.  hope that's because of update due tomorrow
