Webby
Message 11 of 16
Re: Reason for Fibre being unavailable.
No, the OP is with TalkTalk.
Webby
Message 12 of 16
Remove your number.
Keith_Beddoe
Message 13 of 16
Please edit out your number, as this is a public forum.
That is most likely the reason. You need a working BT Retail phone line to order BT Infinity, which is why you are not making any progress.
You would have to transfer your phone service to BT Retail first, then you should be able to progress an order.
Keith_Beddoe
Message 14 of 16
I can see that now, thanks.
RobbieMac
Moderator
Moderator
Message 15 of 16
Hi @Daveo4
I have sent you a few private messages.  Can you read these when you get the chance?
You'll see your PM's when you're on the home screen and you'll see an envelope beside your username.
Cheers,
Robbie
Daveo4
Message 16 of 16
Thank Robbie read and understood.
FTTP said they can only go by there database and that I should contact openreach by filling in a form (which I have now done for the 3rd time ..) 😞
