Message 1 of 5
Received two Sim Cards
signed up to BT mobile, This morning I received two sim cards in the mail can anyone tell me the reason for sending two sim cards as I only ordered one
4 REPLIES 4
Message 2 of 5
Re: Received two Sim Cards
Do they have the same phone number attached?
If not might be worth double checking your order confirmation, and if there's been 2 ordered by mistake you might need to speak to the cancellations team so you don't get charged.
Message 3 of 5
thanks for the reply, just checked and they both have the same number ? is there a reason for this
Message 4 of 5
Probably just error, unless you asked to have another one sent if the first was late? Either way only 1 of them will be active, so you can dispose of the other just to avoid any mixup down the road.
Message 5 of 5
thanks 😀
