Message 1 of 5
Recent drop in speed from slow(ish) to VERY slow...
Hello,
I live in a rural area.
We have BT Broadband which is not the fastest but which is reliable.
On approx. 19/10/2010 we went away for a couple of days.
On returning we have very slow broadband.
Here are some results (using Speedtest.net)
(DATE / DOWNLOAD / UPLOAD / LATENCY)
12/10/2010 - 0.73mb/s - 0.34mb/s - 83ms
14/10/2010 - 0.73mb/s - 0.33mb/s - 85ms
15/10/2010 - 0.73mb/s - 0.31mb/s - 84ms
The above are acceptable. But we have just come back and get these speeds:
23/10/2010 - 0.13mb/s - 0.16mb/s - 922ms
24/10/2010 - 0.11mb/s - 0.29mb/s - 611ms
24/10/2010 - 0.14mb/s - 0.33mb/s - 205ms
Nothing has changed at our end (same BT Home Hub in use etc. etc.)
This is the result this morning (24/10/10) using the BT speedchecker:
Download speedachieved during the test was - 102 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :512 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
I realise we'll never get blistering speeds, but I am concerned about the drop.
Any thoughts?
Many thanks,
Simon
4 REPLIES 4
hamish72
Recognised Expert
Message 2 of 5
Re: Recent drop in speed from slow(ish) to VERY slow...
enter  if home hub
192.168.1.254 in browser click A to Z top right
then ADSL enter pas and click MORE DETAI
post full results
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Message 3 of 5
Thanks Hamish.
Details below (hope this is what you wanted).
Cheers,
Simon
ADSL line status
Connection information
Line stateConnected
Connection time6 days, 17:19:56
Downstream512 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)20.1 dB / 13.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)14.2 dBm / 12.4 dBm
Loss of Framing (Local)49
Loss of Signal (Local)9
Loss of Power (Local)0
FEC Errors (Down/Up)3768 / 744
CRC Errors (Down/Up)90 / 2147480000
HEC Errors (Down/Up)nil / 444
Error Seconds (Local)3020
hamish72
Recognised Expert
Message 4 of 5
You need to get that SN margin down if possible as with 63  attenuation indicating a fairly long line its the only way to increase sync speed
Have you tried a quite line test from master or test socket
dial 17070 option 2 and listen - should hear nothing
best done with old type analogue phone digital will do but may have slight hiss
do not use home hub phone
and look at this may help
Message 5 of 5
Thanks Hamish.
I'll look into that.
I know that we live almost at the 'end of line' from the exchange so accept we're never going to get the quickest broadband.
But I can really 'feel' the drop from 0.7mbps.
It'll be interesting to see if it improves during weekdays.
Thanks,
Simon
