Hi,
I have been with BT for a long time and all of a sudden (last couple of months maybe) whenever someone else in the house uses Netflix my games lag.
I don’t know why, we have not changed/introduced anything so I can only assume BT have changed something?
Can something be changed, looked up from the BT end?
I have searched the forums and I see other people have had the same experience:
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Extreme-ping-lag-in-games/m-p/1910219
https://community.bt.com/t5/Home-setup-Wi-Fi-network/BT-Infinity-Lag-Spikes/td-p/1890814
I have tried to follow these to posts and enable QoS but for some reason no matter what I change in they QoS settings it makes no difference.
My router is the TP-Link AC2800 and my QoS settings are below.
I have added the 4 devices that have the ability to stream Netflix to low priority and added my gaming machine to high priority.
I have also reserved the IP’s for all of the devices.
No matter what settings I use my games always lag like clockwork when Netflix is played, its almost as if QoS isn’t working.
I do have other devices on LAN/WLAN (phone, extender and echo dot) but they don’t create much bandwidth and I don’t want to create to much of a complex QoS rule list.
I assume these not being added is not creating an issue. When I tested today I only had these 5 items connected to the network.
Any help is much appreciated.
Thanks Gareth
Since renewing my contract just before Christmas 2018 for a further 24 months I am having constant issues to the point where I feel like I've gone back a decade. Previously I had fibre infinity with no problems for 2 years. Within a couple of weeks of renewal I've been having constant issues to the point that if somebody in the house is streaming, any gaming becomes unplayable due to constant and erratic high ping fluctuations.
I have researched on line for a solution and have held numerous discussions via BT chat and gone through all suggestions with no joy to these constant issues.
I am left wondering if my package has been amended in any way that I am unaware of as there were no issues prior to renewal. I have seen many people suffering similar isssues whilst browsing community posts which generally seem unresolved. The only resolution I have seen that appears relevant is a change to a stable service or a very stable service.
Currently there are two gamers and three people constantly streaming in the same household. If anyone is streaming no-one can play on multi player games without having constant ping fluctuations that make the game unplayable.
I have replaced the home hub 6 with a third party router that can handle QOS but the issue still remains. I have cut down to using one PC connected directly to the router via ethernet and the issue still remains. Cables have been changed with no effect. I have checked the line for noise which appears to be fine and exhausted all internal options and remain convinced there is an external issue.
I would very much appreciate any help with this issue and hope to resolve this soon.
I had this problem occur in December 2018 and after 2 months I gave up as I'm moving home soon. Cannot game at all because of ping spikes and I had no problem for the 2 years I have been with BT until December 2018. Since I'm leaving home start March I gave up trying to fix it. Good luck
Hi,
Have you fixed this?
I am now having the same issue after being with BT for 2 years and not having any problems. I only noticed it 2-3 weeks ago, but it is becoming a big issue when 2 people in the same house are trying to game/stream on netflix.
I contacted BT who sent me a new router, but it has not made a difference.
TIA
Hi,
I haven't fixed the issue but I have improved it by purchasing a managed switch (£30 from curry's) which plugs into my router and I am able to restrict the bandwidth used for each port.
My netflix devices are on LAN so I was able to achieve this, if your devices are using wireless then there is extra steps to take, like using a wired AP device.
I have found lots of topics on the CS and Overwatch forums about this issue, they all start from the back end of last year with the exact same symptoms.
There are a few theory's on what BT are doing on other forums, namely, BT using some kind if QoS for streaming sites and placing people who download a lot or download at awkward times at the bottom of the pile.
I do not think you will get any response here, from reading a few threads they always think its the end users fault but its far to big of a coincidence for that.
Its very odd that I have to use QoS and monitor bandwidth all of a sudden after using BT for over 10 years and yet the speeds are faster than ever!
Like most others with this issue, I would prefer slower download rates and a more stable gaming ping.
Thanks Gaz
Happening to me, even using a XR500 router, when i use twitch on another device, my pings go crazy on every game i play. I have a 80/20 connection and this has started happening the last few weeks. I even tried just having a ps4 connected a one phone connected to the router and the lag spikes keep happening
