There is a new layout now where you can no longer press the blue Y button and see your recordings and programmes set up to record. At first if I scrolled down to the strip entitled My TV I could call that up with the blue Y button but it won't even do that the last day or so. I hate this new layout, can I revert back and how can I see my programmes set up to record?
Solved! Go to Solution.
If you press the blue button then scroll down to my tv so it's highlighted & press ok it should bring them up
many thanks
Totally agree with you about the new layout.
It's harder to use and slower to load, nothing to recommend it.
