Message 1 of 1
Recommended Setup For Structured Cabling
Hi all,
We have just installed the BT Full fibre 900 product in a home with CAT 6A cabling run from a utility room out to most areas in the property.
Having done a quick bit of research it seems the highest WiFi speeds would be attained by a installing series of access points or something like a Mesh system with ethernet backhaul.
Does anyone have recommendations or experience with  PoE capable routers & Access Points  that can replace the BT Smart Hub or perhaps even suggest an alternative network configuration.
I am aware that I will lose the bundled Digital Voice product unless I keep the BT Smart Hub or daisychain the new router off the existing BT hub.
