Message 1 of 7
Recording jumping and freezing
Hi my records keep jumping and freezing or stopping I just got the TV box connect Wednesday I watch a recording Wednesday and it don't freezer or stop or jump it just started Thursday can any one help please I checked all the wires and the hub and I check live TV and it's working or fine
6 REPLIES 6
Message 2 of 7
Re: Recording jumping and freezing
Hi @MSmith37 welcome to the community and thanks for posting, I'm sorry that you're experiencing problems when playing back recordings.
Can you try a reset on the BT TV box and let me know if it helps?
Neil
Message 3 of 7
@MSmith37
Are these recordings the normal Freeview channels or subscription channels like BT Sport etc?
Answer this before doing any form or reset.
Message 4 of 7
It has been what I recorded on Freeview I not recorded anything on subscription but it was working fine the other day on Freeview recorded channels. It just started Thursday.
Message 5 of 7
Hi thanks I give it a go today
Message 6 of 7
It's a new box to
Message 7 of 7
Hi thanks I reset it and it same to be working now but it's a new box I just plugged it in 2 days again don't think it need resetting.
