Message 1 of 3
Recordings
  • I am in the process of changing my BT vision + box for You View can anyone tell me if it is possible to save some of my recordings on my old box to the you view. thanks.
2 REPLIES 2
Message 2 of 3
Re: Recordings
No, not unless you play them all and save them to an external DVD recorder. This would only work for content that was not copyright protected.
Message 3 of 3
Re: Recordings
Thanks for your reply I did not think it would be possible .Regards.
