Message 31 of 45
Re: Recurring Broadband Interruption
Engineer visited neighbour's house and call was closed as "no fault found".  He replaced master socket with latest variant (I guess this is done automatically).  And speed is back up. For how long nobody knows...
Your DSL Connection Rate :6.3 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
Message 32 of 45
profile still incorrectly showing 7.15mb
Message 33 of 45
Neighbour (working at home today) has reported connections dropping in the last hour or 2. BT speedtest is failing (but ok on my number).  Bouncing back to BT (not quite sure who to specifically).
Message 34 of 45
presumably back to tech team who you were dealing with and arranged the engineer visit.
has conenction speed dropped really low again with high noise margin?
Message 35 of 45
speed test (at property)
Download speedachieved during the test was - 3.52 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.49 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
router stats (those I could find with my crappy router)
Downstream
Upstream
SNR Margin14.030.0dB
Line Attenuation31.418.5dB
Message 36 of 45
not as low a connection speed as before but lower than it should be - are you able to go back to tech team you were dealing with?
Message 37 of 45
Yep - engineer #2 being arranged.
Message 38 of 45
Fingers crossed for a better result this time. Lol
Message 39 of 45
Its a tricky one. Guess an engineer will have a plan for random line drops.
Message 40 of 45
Await next instalment
