Message 41 of 45
Re: Recurring Broadband Interruption
Engineer visit #2 was at neighbour's this morning.  Will advise what happened later but stats are
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
Message 42 of 45
that looking fine now as it should do max speed for ADSLMAX
Message 43 of 45
you missed off the download speed which was the problem as previous stats had the correct profile of 7.15mb
Message 44 of 45
Just visited neighbour (after enginer#2 visit on Monday).  d/l speed is fine and profile is fine.  So what did the engineer do? At the pole by the house he "adjusted/removed some legacy/unused? "star-wired" alarm connections".  Neither myself nor my neighbour understood any of this but appears fixed!  Where's the fixed button...
Message 45 of 45
That's great. Took a while but sounds perfect. Only the thread originator can mark the pst solved
