Message 1 of 9
Red WAN Cable connection issues
My fledgeling dip into 'I will do it myself' attitude has hit a speed bump.  I've just received my new smart hub in the post and it has a RED WAN connection as well as a Red ended cable included.  I can see where the red connection goes on the new hub but I'm at a loss as to where the other end of the red cable goes.
8 REPLIES 8
Message 2 of 9
Re: Red WAN Cable connection issues
@Chunk66
What type of broadband connection do you have?
Do you have a direct optical fibre into the house, or does your broadband come down the phone line?
Message 3 of 9
Sorry to sound dumb, but what do you mean type?
Message 4 of 9
Ahh,  phone line.
Message 5 of 9
Direct optical fibre, with an Openreach unit on the wall, with lights on it. Or just a phone socket on the wall.
Message 6 of 9
@Chunk66 wrote:
Ahh,  phone line.
Then you do not use that red lead at all, you use the grey RJ11 lead, and connect it to your phone line.
I think BT are sending the same smart hub for both fibre and copper services.
Connect it up as shown below.
Message 7 of 9
Double socket set up with internet on the left and phone on the right.
Message 8 of 9
Thanks Keith as the whole red cable issue had me convinced i was missing out on a connection.
Message 9 of 9
The red cable is used to connect to an Openreach optical modem, similar to this.
These are now being installed in most new build properties, and where there is a very slow broadband connection.
BT have been sending out two types, but I suspect they are now just sending out the one type, with an option to use the WAN connection, as a normal Ethernet port.
Saves making two types, and easier to upgrade customers to fibre.
