Message 1 of 12
Rediculously slow speeds and poor customer service!
Unfortunately, I've been unable to find help anywhere else so here I am asking the community.
Recently I changed my broadband provider from sky to BT infinity hoping to get faster speeds and a more reliable network (oh how I was wrong). Since having BT infinity I've encountered a number of problems. Main issues are the speed of the network and the connection to the network. The connection seems to work for a wee while then either show up as NO CONNECTION on the computers (Windows) or the hub itself alternates between flashing orange and continuous orange.
When the internet, however, does work we get speeds of around 10MB-15Mb (and that's on a good day). Now looking at the deals on BT's website it shows Standard Broadband with up to 17Mb and Infinity with up to 52Mb. I'm not even getting the minimum 17Mb.
Going on to look at the estimated speeds at my address or phone number it shows:
Estimated speeds:
27Mb-39Mb - 'Great news! You could get up to 39Mb speed'
The same result says my MINIMUM GUARANTEED SPEED:
Estimated download speed (Minimum speed 'guarantee'*) range:
22Mb
Something has to be wrong, people in my area that I know have normal speeds up to 37MB. I've been on to BT's submit a fault area where I ran some tests then it said it would do more and contact me.... nope it now says resolved but still no better. Whilst running these tests it said and I quote ... "We've finished the test and haven't found any faults on the network, but we can see you've still got a problem."
What can I do? It seems I could be still connected to the old Standard Broadband connection.
Trying to contact BT directly is a nightmare from live chats (that I don't have time for) to lack of proper email support.
This close to Christmas is extremely inconvenient for the family. I've taken to tethering my phone to my PC to get a reliable network, which is costing even more. Luckily my phone isn't with BT because I don't think I would be able to cope.
Thanks to anybody that can help.
11 REPLIES 11
Message 2 of 12
Re: Rediculously slow speeds and poor customer service!
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then scroll down the page and carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If you have a Homehub 5 can you post the stats from 1-12 by logging onto the Homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
or
If you have the Smart Hub, (Homehub 6) can you go to hub manager then advanced then technical log and post the stats. http://bthomehub.home/
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 3 of 12
Thanks for fast reply,
Working backwards ... calling 17070 then selecting 2, there is a muffled hiss in the background and at the start what sounded like a beep... Next bit is interesting (IP Profile)
Next the Availability Test:
Finally the technical log:
Product name:
BT Hub 6A
Serial number:
+084316+NQ62856829
Firmware version:
SG4B1000223E
Firmware updated:
26-Nov-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 28 Minutes 34 Seconds
Data rate:
1.08 kbps / 13.10 kbps
Maximum data rate:
1077 / 16343
Noise margin:
6.5 / 10.1
Line attenuation:
24.5
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
18 MB Uploaded / 307 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-ZQ2G
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-ZQ2G
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
40:C7:29:18:BF:77
Software variant:
Boot loader:
7.33.1
______________________
Thanks for your help !!
Message 4 of 12
Lewis i feel your Pain. You would think a very reputable company such as BT would have alot better services, mind you they dont rank worst in ofcom's ratings for nothing. Smiley Indifferent
Spoiler
Message 5 of 12
Urgh! Hope it can be sorted soon, preferably before Christmas. Just tedious actuality getting in contact with a real person and not an automated call service or automatic test. BT definitely need to revise their customer support strategies.
Message 6 of 12
Yes they certainly do. The company just doesnt seem to care.
Message 7 of 12
Just for info in case you were not sure. Your IP profile is set by your speed, not the other way round.
Your noise margin is high which can indicate a fault.
Are you connected to the master socket?
If you are can you remove the face plate and connect to the test socket.
Once you have done that, check that any telephone extensions you may have have no dial tone and then re-run the speed test and re-post the hubs stats.
If there is no noticeable difference to your speed and stats you will need an engineer visit.
Message 8 of 12
Hello,
Thanks for your reply!
I'll do this test later on because I'm unable to do it at the moment. I'll keep you posted. Just so I'm sure by hub stats do you want everything again or just the IP profile and technical log ?
Thanks again
Message 9 of 12
Hub stats and diagnostic speed test will be fine.
Message 10 of 12
Okay,
Sorry about the late reply, just been busy due to christmas.
Done the tests and its not made any difference.... How should I go about getting an engineer to come and look at it?
All tests done with ethernet connection.
Product name: BT Hub 6A
Serial number: +084316+NQ62856829
Firmware version: SG4B10002244
Firmware updated: 22-Dec-2016
Board version: 1.0
Gui version: 1.32.0
DSL uptime: 0 Days, 0 Hours 5 Minutes 55 Seconds
Data rate: 7.48 kbps / 13.10 kbps
Maximum data rate: 7478 / 37093
Noise margin: 6.1 / 19.1
Line attenuation: 24.5
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 26 MB Uploaded / 39 MB Downloaded
Broadband username: bthomehub@btbroadband.com
BT Wi-fi: Active
2.4 GHz wireless network name: BTHub6-ZQ2G
2.4 GHz wireless channel: Back Smart (Channel 1)
 Technical log
Information Event log
BT Smart Hub Manager
12/27/2016 Information
http://bthomehub.home/0000013200/gui/#/technicalLog/information 2/2
5 GHz wireless network name: BTHub6-ZQ2G
5 GHz wireless channel: Smart (Channel 36)
Wireless security: WPA2 (Recommended)
Band steering: Off
Wireless mode: Mode 1
Firewall: On
MAC address: 40:C7:29:18:BF:77
Software variant: -
Boot loader: 7.33.1
