Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
About 3-4 weeks ago the broadband light on our HomeHub 3 went out for an unknown reason. A simple reset did not fix the problem so I called BT technical support who informed me that there were no issues in the area and advised to plug our HomeHub 3 into the master socket. I did this and eventually after about half an hour the broadband light came back on. I then plugged the HomeHub 3 back into its original socket and it proceeded to work fine. Our line speed however was reduced from 7.5 Mbps to 5.6 Mbps. Searching for solutions directed me to threads in this forum where others had been advised to wait a few days for the line speed to return to normal. I followed this advice and unfortunately this has not happened and so I have now registered here to ask for our line speed to be manually returned to normal.
I understand that in order to do so I must post our ADSL line status from the HomeHub 3 with a minimum of 3 days connection time. I am unable to do this as our HomeHub 3 has developed a fault, whereby after an hour or so, the manager can no longer be accessed at either http://192.168.1.254 or http://bthomehub.home/. A temporary fix is to reboot the HomeHub 3 which resests the connection time. The following is our ADSL line status after rebooting:
ADSL Line Status
Connection information
Line state: | Connected |
Connection time: | 0 day, 00:09:07 |
Downstream: | 5,632 Kbps |
Upstream: | 256 Kbps |
ADSL settings
VPI/VCI: | 0/38 |
Type: | PPPoA |
Modulation: | G.992.1 Annex A |
Latency type: | Interleaved |
Noise margin (Down/Up): | 6.0 dB / 7.0 dB |
Line attenuation (Down/Up): | 28.5 dB / 31.5 dB |
Output power (Down/Up): | 19.8 dBm / 12.3 dBm |
FEC Events (Down/Up): | 23265 / 0 |
CRC Events (Down/Up): | 0 / 0 |
Loss of Framing (Local/Remote): | 0 / 0 |
Loss of Signal (Local/Remote): | 0 / 0 |
Loss of Power (Local/Remote): | 0 / 0 |
Loss of Link (Remote): | 0 |
HEC Errors (Down/Up): | 0 / 0 |
Error Seconds (Local/Remote): | 0 / 0 |
After monitoring the connection for half an hour before being unable to access the homehub again, the Noise Margin had changed to 7.1 dB/7.0 dB and the Output power to 19.9 dBm/12.3 dBm.
Slightly off topic, ADSL 2+ has within the last month become available in our area, will we have to ask BT for the faster speeds or will we be automatically upgraded? Also, our ADSL line status shows that we have an Interleaved latency type, is it possible with our line attentuation and noise margin to be put onto Fast Path?
Thanks for taking the time to read the post.
Hi John, thanks for the fast reply. Here is the ADSL line status when plugged into the master socket:
ADSL Line Status
Connection time: | 0 day, 00:05:14 |
Downstream: | 8,128 Kbps |
Upstream: | 448 Kbps |
VPI/VCI: | 0/38 |
Type: | PPPoA |
Noise margin (Down/Up): | 14.4 dB / 23.0 dB |
Line attenuation (Down/Up): | 6.0 dB / 3.5 dB |
Output power (Down/Up): | 11.8 dBm / 12.0 dBm |
FEC Events (Down/Up): | 0 / 0 |
Thanks for the information regarding ADSL2+. As for the latency type, I do a lot of gaming so Fast Path would be better. How can I go about having the change arranged?
Hi John, thanks again for the fast reply. I am going to move the Home Hub 3 to a new location so it can permanently be plugged into the master socket. What can I do about the faults with the Home Hub 3 and not being able to access the Home Hub manager after a short period of time? This will prevent me from being able to paste the ADSL line status in 3 days time show a stable connection.
Ok John thank you for your help. I am ordering a couple of new cables so I can keep the Home Hub permanently plugged into the master socket. Once they arrive and it's all in place, I'll wait 3 days and post back here with some new stats.
Hello again, the Home Hub 3 has now been in its new location plugged into the master socket for 3 days. The Home Hub manager is now working fine and so I am now able to access it any time. Here is the current ADSL line status:
ADSL Line Status
Connection time: | 3 days, 00:09:34 |
VPI/VCI: | 0/38 |
Type: | PPPoA |
Noise margin (Down/Up): | 14.5 dB / 24.0 dB |
Line attenuation (Down/Up): | 6.0 dB / 4.0 dB |
FEC Events (Down/Up): | 1756 / 20 |
CRC Events (Down/Up): | 35 / 1 |
HEC Errors (Down/Up): | 487 / 1 |
Our IP profile has been raised to it normal level also:
1. Best Effort Test: -provides background information.
Download Speed | |
6.94 Mbps |
0 Mbps | 7.15 Mbps Max Achievable Speed |
Download speed For your connection, the acceptable range of speeds Additional Information: Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 7.15 Mbps |
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit the FAQ if you are unable to understand the test results.
