JohnSPR
Message 1 of 14
Reduced upload speed - ADSL 2+
Good morning,
I usually get around 0.75 upload speed. However for the last few weeks (maybe longer actually) I can only get around 0.35 up. I have experienced the same problem in the past on different accounts, where I had been taken off ADSL 2+ and moved back to regular ADSL connection, so I guess it the same issue on this account.
Can someone help to resolve please?
Details below:
1. Product name:BT Home Hub
2. Serial number:+068340+NQ42236443
3. Firmware version:Software version 4.7.5.1.83.8.130.1.26.1.1 (Type A) Last updated 28/10/15
4. Board version:BT Hub 4A
5. ADSL uptime:0 days, 00:16:57
6. Bandwidth:444 / 5720
7. Data sent/received:6.5 MB / 71.6 MB
8. Broadband username:bthomehub@btbroadband.com
9. BT Wi-fi:Yes
10. 2.4 GHz Wireless network/SSID:BTHub4-9K7K
11. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID:BTHub4-9K7K
15. 5 GHz Wireless connections:Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic (Smart Wireless)
18. Firewall:Default
19. MAC Address:40:f2:01:4d:3a:fa
20. VPI/VCI:0 / 38
21. Modulation:G.992.3 Annex A
22. Latency type:Interleaved
23. Software variant:-
24. Boot loader:-
Thanks,
JohnSPR
13 REPLIES 13
imjolly
Message 2 of 14
Re: Reduced upload speed - ADSL 2+
you are not back on adslmax as can be seen from your modulation.
your conenction time is only 16min is that due to manual reset or router dropping connection
JohnSPR
Message 3 of 14
Hi imjolly,
Yes I tried a final manual reset before reporting the issue here - it didn't work.
You're right about the modulation type, but this was the same when I had an identical problem on my other account (maybe I used wrong terminology in my first post).
Anyway, all I know for sure is that when someone from the team called me last time they confirmed that my up speed had been lowered (mass migration or something? not sure), anyway they then re-instated to the higher speed and problem was solved overnight. So I'm  hoping the same thing can be done on this account.
Thanks,
John
john46
Message 4 of 14
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
JohnSPR
Message 5 of 14
Hi john46,
Below as requested:
09:09:15, 09 Jul.( 107.770000) DSL noise margin: 23.80 dB upstream, 3.00 dB downstream
09:09:14, 09 Jul.
( 107.290000) DSL line rate: 444 Kbps upstream, 5720 Kbps downstream
Thanks,
John SPR
PaddyB
Moderator
Moderator
Message 6 of 14
Hi @JohnSPR,
I'll be able to take a look at your connection. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
JohnSPR
Message 7 of 14
Hi PaddyB,
I have comeplted the contact link as requested. I look forward to hearing from you.
Thanks,
JohnSPR
JohnSPR
Message 8 of 14
Morning PaddyB,
Whats the average response time for these sorts of issues? I would really love to get it resolved before the weekend if at all possible.
Regards,
JohnSPR
NeilO
Moderator
Moderator
Message 9 of 14
@JohnSPR Sorry about the delay getting back to you. I can see you're next in our queue so we should be in touch today.
JohnSPR
Message 10 of 14
Hi NeilO,
That's great news, I look forward to hearing from you.
Regards,
JohnSPR
