Supersonicairliner
Message 1 of 6
Reducing connection speeds
Hello,
I have had Infinity 1 for some time now (signed up for Infinity 2 then found max speed avail 32 MB but thats another story). Supplied with  Home Hub 5 and connected at 31105 and 4715 on 12/3/16. Fine.
Since then the connection speeds have been declining steadily, 30.7 and 4.4 on the 7/5/16. 30.2 and 3.9 on the 17/6/16.
Then 29.9 and 3.9 on 16/7/16.
So I decided to get the Smart hub and hope the problem is solved..............er no.
First connection a couple of days ago shows 26.6 and 3.9. disconnecting and reconnecting gives the same.
How slow can it get and why is it slowing down?
All data from relavent hub. ADSL availability for my line is 32MB.
5 REPLIES 5
Webby
Message 2 of 6
Re: Reducing connection speeds
Can you run your number on this checker http://www.dslchecker.bt.com and post a screenshot of the results please.
Supersonicairliner
Message 3 of 6
Thanks for the reply. Max speed to expect is 32. Thats what I was gettig at the start.
BT BROADBAND AVAILABILITY CHECKER
Telephone Number by Cabinet 3
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  HighLowHighLow
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)32.4256.54.5--Available----
VDSL Range B (Impacted)24.612.64.41.2--Available----
WBC ADSL 2+Up to 17.5--15.5 to 19Available----
WBC ADSL 2+ Annex MUp to 17.5Up to 1.515.5 to 19Available----
ADSL MaxUp to 8--7 to 8Available----
Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Webby
Message 4 of 6
You're above the minimim expected downstream sync speed of 25meg.
Some have experienced worse connection rates with the smart hub. I'd be tempted to go back to the hub 5 as with 29.9meg, you're almost at the top end of what's expected on your line.
I'd return the smart hub and request a refund as it's not fit for purpose in your case.
Supersonicairliner
Message 5 of 6
Thanks for that webby, so much for the improved, all singing dancing smart hub. I dont get new things to go backwards!
BT still try and advertise an upgrade for me to 76 Meg which I know is impossible. Im sure they will sell it to me as well, assuming ignorance.
Back to the HH5 then!
Cheers!!
Super
Webby
Message 6 of 6
It's just that some chipsets work better or worse on some lines, not that one is universally better or worse than the other.
