Jope1983
Message 11 of 17
Re: Refuing to fix issue
on Exchange ABERDEEN WEST is served by Cabinet 5
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 80 67.8 20 20 -- Available -- --
VDSL Range B (Impacted) 71.9 39.2 20 10 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 7 -- 6 to 8 Available -- Yes
WBC ADSL 2+ Annex M Up to 7 Up to 1 6 to 8 Available -- Yes
ADSL Max Up to 3.5 -- 2.5 to 4.5 Available -- --
WBC Fixed Rate 2 -- -- Available -- Yes
Fixed Rate 2 -- -- Available -- --
Other Offerings
Jope1983
Message 12 of 17
Getting the speed test rusults to copy. The resutls are dl 23.6 ip profile 23.2. Acceptable range 20-23.2 up 6.72 ip profile 10. If I can figure our where I am going wrong I will post the reaults from a test
Jope1983
Message 13 of 17
Webby
Message 14 of 17
Have you tested into the test socket by removing the faceplate from the master socket?
Jope1983
Message 15 of 17
No what would I be looking for?
imjolly
Message 16 of 17
Connecting to test socket may improve your connection as it eliminates all your internal wiring from causing a problem. You need to check when conencted to test socket that your phone extension sockets do not have a dial tone
Jope1983
Message 17 of 17
I have tried this with no great change to test results. I have been told by on of the several engineers that have pretenteded they where trying to fix my issue that 22 mbs was the optimal speed for my line as the cabling is not really fit for broadband guven its age. He also told me that he had been instructed to say that about my optimal speed not the state of the cables regardless of whatever tests he had done said.
