clairelouise2
Message 1 of 6
Regarding upload.
This isn't too big a problem, but something I have always noticed with my connection and I wonder if it is a fault I should get looked at. I get a great download speed - used to be around 69mb but has actually gone up in the last 6 months and is now usually betweem 74-76mb which is right where I should be for my range A line (estimated 72-80mb) However, my upload is consistently below estimates - estimate for range A is 20, for B is 12.2 - 20. I never manage to break 10mb. Usually it hovers at around 9. I find this quite strange and am wondering if there could be a reason why this is. All checks are done wired.
5 REPLIES 5
ray_dorset
Distinguished Guru
Message 2 of 6
Re: Regarding upload.
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
clairelouise2
Message 3 of 6
I don't have a HH5, just a HH3..
ray_dorset
Distinguished Guru
Message 4 of 6
Oh sorry, the lack of line stats could be a problem.
Instead can you run this speedtest please and post the graphs, or a link to the results? http://labs.thinkbroadband.com/ispa/
clairelouise2
Message 5 of 6
ray_dorset
Distinguished Guru
Message 6 of 6
I've seen other posters who have had this issue fixed when a line fault has been fixed by a phone engineer. It may be corrosion or some similar problem but I don't know why it only seems to affect the upstream.
