Guru
Message 1 of 3
Regular disconnections
Every single night between 1 and 2, my internet disconnects without fail, I have had 2 engineers out who have been very helpful but unsuccessful to locate the exact issue. It was suggested to me that this could be a Sky issue, sending information/data or updates for my Sky box's.
Would anyone know this to be true? Has anyone else had similar problems.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
2 REPLIES 2
Expert
Message 2 of 3
Re: Regular disconnections
My guess would be OpenRG or PPP LCP. Look for other posts in this forum and if you are using a HH5 check the logs.
Guru
Message 3 of 3
Ok Thanks, I was originally using the HH5, genuinely thought it was a defective hub. Now using the hh3, I'll check the logs tonight and see what they come back with.
