Message 1 of 5
Remote control problem
The TV & TVAV buttons have stopped working. (only had this remote for 3 months) I have tried resetting both the remote and the Youview box.
All other buttons are working correctly.
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Remote control problem
Do the volume up and down work? if not you need to re-programme your remote with the correct code for your TV
Message 3 of 5
The volume control buttons are working. Only the TV and TVAV buttons not responding.
I tried to find how to re-enter the tv code but was unable to find it.
Anonymous
Not applicable
Message 4 of 5
The volume control will still work even if the remote control has not been coded but it is contolling the volume on the box not on the TV, this is usually evident by the appearance on screen.
Follow the instructions here to find the correct code for your TV and programme the remote
Message 5 of 5
Thank you the solution worked.
