JnL73T
Message 11 of 27
Re: Removing multiple BT extensions - help needed with 3 way junction
OK, so i've got myself in a bit of a pickle.
I have disconeccted the ADSL box from the lounge and moved it to the kitchen where the external line comes in the house.
I then connected the orange wire to B and the white wire to A (these were screw connections so nice and easy). With the ADSL faceplate off I connected the phone line to the test socket in order to test the line and it is dead....whooopps.
Any ideas what i may have done wrong?
Keith_Beddoe
Message 12 of 27
The incoming line would normally be blue and blue/white. That should be easy to identify if it comes from outside.
JnL73T
Message 13 of 27
The incoming line has an orange/white and a black/green cable in it. The black/green has never been used.
JnL73T
Message 14 of 27
Here is where i currently am. Connected the orang to B and white to A. Tried the test socket with the phone but no line 😞
Keith_Beddoe
Message 15 of 27
It depends on what junction box you are talking about  Does your line come in from a pole, or direct underground?
Are you sure you have actually identified the incoming line?
JnL73T
Message 16 of 27
The line comes in from a pole.
Keith_Beddoe
Message 17 of 27
Then there will be a junction box where the drop wire joins to the internal  cable.
One of these Dropwire connection block or BT52a or BT 78A
From that junction box, normal internal telephone wiring would be used, which is fire resistant, but not waterproof.
JnL73T
Message 18 of 27
ah, odd it has suddenly started working - must be a loose connection in the box i reckon.
Keith_Beddoe
Message 19 of 27
That would not be unusual, it may be worth you replacing it, as its likely to give trouble in the future. The spring contacts get worn out.
If you are going to keep any extensions, they must be wired to the filtered side of the socket.
Which one do you have Filtered sockets
licquorice
Message 20 of 27
That is definitely the incoming line, previously crimped to the blue pair of the removed grey cable.
