JnL73T
Message 21 of 27
Re: Removing multiple BT extensions - help needed with 3 way junction
Ok, so now i've removed all the extensions. I just have this as the master socket where the wire enteres the house:
I recently found out our local cabinet is about to be connected to fibre so I'll try and get the box updated when I get the FTTC connected.
Out of interest will BT/Openreach need to come to the house to connect the FTTC? Will I need a new box/faceplate when I get connected?
When I get it connected I'd prefer to get the master socket moved (!) via a wire externally so that it eneters the house in the middle of the hiouse. (Currently the master socket is in the middle of the kitchen wall!).
Keith_Beddoe
Message 22 of 27
You can still use that for BT Infinity, its self install so you will not get a visit unless your speed is below the minimun guarateed speed..
If you wanted the master socket moved, then you would have to pay £130.
JnL73T
Message 23 of 27
Thanks, and if I wanted to replace the box (incase of damage) what extactly do I need to buy?
Keith_Beddoe
Message 24 of 27
This is the latest
Openreach MK4 VDSL Plate & NTE5C Socket - Combined Unit
JnL73T
Message 25 of 27
Thanks. Can I fit one of those now i.e. before I get upgraded to FTTC fibre?
Keith_Beddoe
Message 26 of 27
If you want to.
imjolly
Message 27 of 27
This may help. https://www.openreach.co.uk/orpg/home/helpandsupport/how-toguides/howtoguides/downloads/NTE5C_Instru...
