My data rate used to be around 47/10, my BT contract was up so I called up and agreed to the "Superfast Fibre 2 Unlimited" package, it was activated yesterday morning but my data rates have dropped to 32/10.
Here is a screenshot of what I did get at one point (apologies for the poor photo 🙂
What I am getting today:
I did have issues before with data rates being capped, but this thread solved the issue, and I went from 40/2 to 47/10 and I was thrilled -- https://community.bt.com/t5/BT-Fibre-broadband/Low-modem-upload-sync-speed/td-p/1910515
Any ideas?
Moving to the new profile has caused a DLM reset. Give it a few days and your speed will return. Don't expect it being any faster than before though.
I hope you didn't pay any more because your line isn't capable of exceeding Fibre 1 speeds. Once your line has been stable for a few days you should see the downstream SNR drop from 6dB to 3dB usually in 1dB increments as DLM tests for stability as it drops the margin - each 1dB drop will increase your speed slightly.
