ryanm
Message 1 of 16
Repeat and random disconnections - time for a replacement hub?
Hi all,
For the last few weeks I have been suffering from repeated and random disconnects using btbroadband.  Prior to this, absolutely not a problem with bt apart from a faulty v1 homehub a few years back on installation at our home.
We currently have two devices connected through the homehub 2.0 - a laptop and a desktop (both wired).  Since I am of today due to the royal wedding (thumbs up will) I decided to catch up on some on demand programs using my bt vision service.  That began randomly throwing v04 errors which suggests problems with the hub (that much I know).  At that stage I tried accessing the internet on both the laptop and the desktop - nothing.  I powered down the vision top box and restarted the home hub.  Now all is working but the repeated drop outs on the internet and vision service are beginning to get frustrating.  Once the internet drops out it's usually taking around 10-30 seconds for it to come back.  The line state (as seen in the first log below) still shows as being connected despite this fact.   Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be found will be displayed in the chrome browser on drop out.
Nothing else has changed at our home.  No additional electronic devices have been installed or any other changes made to the computers or the hub.  I'm hoping someone could make better sense of these logs or at least give me some indication as to what is going on.  Thank-you so much for any help
ADSL line status
Connection information
Line state
Connected
Connection time
0 days, 0:48:42
Downstream
19,514 Kbps
Upstream
1,235 Kbps
ADSL settings
VPI/VCI
0/38
PPPoA
Modulation
ITU-T G.992.5
Latency type
Interleaved
Noise margin (Down/Up)
3.5 dB / 6.2 dB
Line attenuation (Down/Up)
19.5 dB / 9.4 dB
Output power (Down/Up)
0.0 dBm / 12.8 dBm
Loss of Framing (Local)
0
Loss of Signal (Local)
0
Loss of Power (Local)
0
FEC Errors (Down/Up)
54520 / 4294967264
CRC Errors (Down/Up)
1 / 2147480000
HEC Errors (Down/Up)
nil / 0
Error Seconds (Local)
1
event log copied earlier:
16:40:18  29 Apr
CONFIGURATION saved by TR69
16:39:39  29 Apr
PPP link up (Internet) [81.151.83.153]
16:39:39  29 Apr
FIREWALL event (1 of 1): deleted rules
16:39:39  29 Apr
PPP CHAP Chap receive success : authentication ok
16:39:39  29 Apr
PPP CHAP Receive challenge (rhost = bras-red5.gw-th)
16:39:32  29 Apr
xDSL linestate up (ITU-T G.992.5; downstream: 19551 kbit/s, upstream: 1205 kbit/s; output Power Down: 21.1 dBm, Up: 12.3 dBm; line Attenuation Down: 19.0 dB, Up: 9.4 dB; snr Margin Down: 6.7 dB, Up: 3.3 dB)
16:39:23  29 Apr
LOGIN User Basic logged in on [HTTP] (from 192.168.1.82)
16:39:19  29 Apr
16:39:18  29 Apr
16:39:14  29 Apr
PPP link down (Internet) [86.174.99.84]
16:39:08  29 Apr
xDSL linestate down
16:38:33  29 Apr
FIREWALL event (1 of 1): created rules
16:38:33  29 Apr
xDSL linestate down
16:33:44  29 Apr
LOGIN User admin logged in on [HTTP] (from 192.168.1.82)
16:33:15  29 Apr
16:19:38  29 Apr
SNTP Synchronised again to server: 213.123.20.170
15:56:20  29 Apr
15:55:44  29 Apr
15:55:44  29 Apr
PPP link up (Internet) [86.174.99.84]
15:55:43  29 Apr
15:55:43  29 Apr
15:55:35  29 Apr
xDSL linestate up (ITU-T G.992.5; downstream: 19529 kbit/s, upstream: 1216 kbit/s; output Power Down: 21.0 dBm, Up: 12.5 dBm; line Attenuation Down: 19.5 dB, Up: 9.4 dB; snr Margin Down: 6.7 dB, Up: 3.3 dB)
15:55:24  29 Apr
PPP link down (Internet) [86.174.99.6]
15:55:11  29 Apr
xDSL linestate down
15:54:39  29 Apr
15:54:39  29 Apr
xDSL linestate down
15:50:56  29 Apr
UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:50:14  29 Apr
15:49:34  29 Apr
15:48:50  29 Apr
15:48:13  29 Apr
15:47:30  29 Apr
15:46:47  29 Apr
15:46:02  29 Apr
15:45:19  29 Apr
15:44:33  29 Apr
15:43:55  29 Apr
15:43:18  29 Apr
15:42:31  29 Apr
15:41:49  29 Apr
15:41:04  29 Apr
15:40:50  29 Apr
15:40:18  29 Apr
15:40:15  29 Apr
FIREWALL event (1 of 7): deleted rules
15:40:14  29 Apr
PPP link up (Internet) [86.174.99.6]
15:40:14  29 Apr
15:40:14  29 Apr
15:40:08  29 Apr
xDSL linestate up (ITU-T G.992.5; downstream: 19588 kbit/s, upstream: 1224 kbit/s; output Power Down: 21.0 dBm, Up: 12.4 dBm; line Attenuation Down: 19.5 dB, Up: 9.4 dB; snr Margin Down: 6.5 dB, Up: 3.3 dB)
15:40:00  29 Apr
15:39:57  29 Apr
PPP link down (Internet) [86.174.12.205]
15:39:50  29 Apr
15:39:44  29 Apr
xDSL linestate down
15:39:44  29 Apr
15:39:40  29 Apr
15:39:38  29 Apr
15:39:12  29 Apr
FIREWALL event (1 of 40): created rules
15:39:12  29 Apr
xDSL linestate down
15:38:55  29 Apr
15:38:11  29 Apr
15:37:37  29 Apr
15:37:05  29 Apr
15:34:45  29 Apr
15:19:38  29 Apr
SNTP Synchronised to server: 213.123.20.170
15:10:39  29 Apr
15:09:57  29 Apr
15:09:43  29 Apr
14:19:38  29 Apr
SNTP Synchronised to server: 213.123.26.170
14:19:38  29 Apr
SNTP Systemtime update: time setting 01:04:00 > new time setting: 14:19:38
15 REPLIES 15
ryanm
Message 2 of 16
Re: Repeat and random disconnections - time for a replacement hub?
Just a little update to the log:
ADSL line status
Line state
Connected
Connection time
0 days, 2:02:46
Downstream
19,514 Kbps
Upstream
1,235 Kbps
ADSL settings
VPI/VCI
0/38
PPPoA
Modulation
ITU-T G.992.5
Latency type
Interleaved
3.5 dB / 6.1 dB
19.5 dB / 9.4 dB
0.0 dBm / 12.8 dBm
0
0
0
127432 / 4294967264
5 / 2147480000
nil / 0
4
JaeSwift
Message 3 of 16
I had same problem, read the topic I posted, gentlemans answer seems to be working so far.. I was disconnecting a few times every hour, no disconnection since.. as of yet.. (45 min)
ryanm
Message 4 of 16
Thank-you very much.  Your problem was related to a wireless connection though right?  unless im reading your post wrong?
Error count still rising  😞
JaeSwift
Message 5 of 16
Yes my problem was with wireless, is yours wired?
JaeSwift
Message 6 of 16
Oh and still no disconnection with me, internet fine still (24 hours later)
ryanm
Message 7 of 16
Thank-you.  Hope you got your issue solved.  I'm on wired yes.  Calling bt today.
ryanm
Message 8 of 16
another little update:
ADSL line status
Line state
Connected
Connection time
0 days, 0:42:26
Downstream
19,514 Kbps
Upstream
1,212 Kbps
ADSL settings
VPI/VCI
0/38
PPPoA
Modulation
ITU-T G.992.5
Latency type
Interleaved
3.4 dB / 6.4 dB
19.0 dB / 9.4 dB
0.0 dBm / 12.6 dBm
10
2
0
64614 / 4294967252
4 / 2147480000
nil / 0
27
JaeSwift
Message 9 of 16
Looks like its back to same old tricks.  Disconnecting again.. So annoying.
ryanm
Message 10 of 16
