We're experiencing repeated connects and disconnects. This happens for all devices, as shown in the log below.
Also the devices often connect to BT FON instead of the proper private network.
In terms of trouble shooting:
15:35:22, 11 Jan. | (243422.450000) Lease for IP 192.168.1.64 renewed by host android-254a2c8e0c443273 (MAC 08:fd:0e:cc:c3:69). Lease duration: 1440 min |
15:35:22, 11 Jan. | (243422.450000) Device connected: Hostname: android-254a2c8e0c443273 IP: 192.168.1.64 MAC: 08:fd:0e:cc:c3:69 Lease time: 1440 min. Link rate: 144.4 Mbps |
15:35:22, 11 Jan. | (243422.350000) Lease requested |
15:35:20, 11 Jan. | ath00: STA 18:0c:ac:2b:c4:75 IEEE 802.11: Client associated |
15:35:20, 11 Jan. | ath00: STA 18:0c:ac:2b:c4:75 IEEE 802.11: Client disassociated |
15:35:19, 11 Jan. | ath00: STA 08:fd:0e:cc:c3:69 IEEE 802.11: Client associated |
15:35:19, 11 Jan. | ath00: STA 08:fd:0e:cc:c3:69 IEEE 802.11: Client disassociated |
15:35:17, 11 Jan. | ath00: STA 88:63:df:9d:4d:91 IEEE 802.11: Client associated |
15:35:17, 11 Jan. | ath00: STA 88:63:df:9d:4d:91 IEEE 802.11: Client disassociated |
15:35:14, 11 Jan. | (243414.060000) Device disconnected: Hostname: udhcp-1-17-1-f0-4f-7c-9a-00-57 IP: 192.168.1.70 MAC: f0:4f:7c:9a:00:57 |
15:35:14, 11 Jan. | (243414.060000) Device disconnected: Hostname: Unknown-64-68-0c-d4-03-fe IP: 192.168.1.69 MAC: 64:68:0c:d4:03:fe |
15:35:12, 11 Jan. | (243412.620000) Lease for IP 192.168.1.64 renewed by host android-254a2c8e0c443273 (MAC 08:fd:0e:cc:c3:69). Lease duration: 1440 min |
15:35:12, 11 Jan. | (243412.620000) Device connected: Hostname: android-254a2c8e0c443273 IP: 192.168.1.64 MAC: 08:fd:0e:cc:c3:69 Lease time: 1440 min. Link rate: 37.4 Mbps |
15:35:12, 11 Jan. | (243412.530000) Lease requested |
15:35:11, 11 Jan. | ath00: STA 18:0c:ac:2b:c4:75 IEEE 802.11: Client associated |
15:35:11, 11 Jan. | ath00: STA 18:0c:ac:2b:c4:75 IEEE 802.11: Client disassociated |
15:35:09, 11 Jan. | ath00: STA 08:fd:0e:cc:c3:69 IEEE 802.11: Client associated |
15:35:09, 11 Jan. | ath00: STA 08:fd:0e:cc:c3:69 IEEE 802.11: Client disassociated |
it appears that it is a wireless problem and not that you are dropping internet connection - nothing in logs about drop in internet connection
have you tried changing the lease time in the hub from 1 day to 21 days?
Yes, it is a wifi problem with the deivces not connecting to the router.
I'm not sure why changing the lease to 21 days will make a difference when the devices are reconnecting and renewing the lease every couple of minutes?
Just covering the basics:
Have you turned off "smart setup" on the Homehub.
See link how to do that.
I'll give that a go.
I've just rebooted the router again in frustration. It usually behaves for a while (highly variable from minutes to days!) after that.
Oh well, that reboot helped for 10 minutes! Smart switch is now off but devices are still getting disconnecting.
I have noticed the router itself is throwing up an error, ie MAC 00:62:2c:75:eb:e8. This only happens for the router not other devices
16:47:04, 11 Jan. | ath00: STA 00:62:2c:75:eb:e8 IEEE 802.11: WiFi registration failed |
Are you just re-booting or factory resetting? Try factory resetting by pressing the recessed button at the rear until the lights flash if you haven't already.
Remember if you do a factory reset you will need to turn off "smart set up", split the SSids etc as the factory reset will restore them all to the default settings.
Still getting the problem after:
I'm also getting the red light for broadband disconnect a couple of times a week.
Phoned the helpline, after going through the standard routines teh call centre latched onto the broadband problem. I said the chap should be able to see that I had called several times before. " Yes I can see that sir". So I asked what he was going to do that was different because this seems like grondhog day. Long pause .... then he booked an engineer visit. At least I'll be able to speak with someone who can do more than read from script.
I know it'll be a waste of time. I suspect the mulitple problems with wifi and broadband infers the hub needs to be replaced. However the call centre can only latch onto one thing.
I guess the engineer won't be able to diagnose the hub, probably only do a proper check on the line?
How on earth do I get someone to send me a new hub? What a shambles.
