dervish
Message 1 of 1
Repeatedly dropping connection sometimes within a min.
Few months ago I had the same errors as this. Story so far... Drops in connection to even wired clients.
There's loads of blocked packets but they seem to cover after this sequence(shown below)
Tried limiting the devices connected but phone, set top boxes and computer it happens with. Also reset the home hub 4A to factory settings... Had an engineer out few months ago for the same checked the line no problem... seemed to fix itself now it's back. Sounds to me like a configuration mistake down the line somewhere tried all I can think, tried BT usual channels no joy.
Really, really, really want to cancel and try another company to be honest.
, 09 Aug. (11617.710000) PPP IPCP Send Configuration ACK
22:47:03, 09 Aug. (11617.710000) PPP IPCP Receive Configuration Request
22:47:02, 09 Aug. (11617.330000) PPP IPCP Send Configuration Request
22:47:02, 09 Aug. (11617.330000) PPP IPCP Receive Configuration NAK
22:47:00, 09 Aug. (11615.160000) PPP IPCP Send Configuration ACK
22:47:00, 09 Aug. (11615.160000) PPP IPCP Receive Configuration Request
22:47:00, 09 Aug. (11614.530000) PPP IPCP Send Configuration Request
22:47:00, 09 Aug. (11614.530000) WAN operating mode is DSL
22:47:00, 09 Aug. (11614.530000) Last WAN operating mode was DSL
22:46:58, 09 Aug. (11613.060000) PPPoA is up -​ VPI: 0, VCI:38
22:46:58, 09 Aug. (11613.040000) CHAP authentication successful
22:46:58, 09 Aug. (11612.910000) CHAP Receive Challenge
22:46:58, 09 Aug. (11612.900000) Starting CHAP authentication with peer
22:46:58, 09 Aug. (11612.900000) PPP LCP Receive Configuration ACK
22:46:58, 09 Aug. (11612.880000) PPP LCP Send Configuration Request
22:46:58, 09 Aug. (11612.880000) PPP LCP Receive Configuration Reject
22:46:58, 09 Aug. (11612.880000) PPP LCP Send Configuration ACK
22:46:58, 09 Aug. (11612.880000) PPP LCP Receive Configuration Request
22:46:58, 09 Aug. (11612.780000) PPP LCP Send Configuration Request
22:46:55, 09 Aug. (11609.780000) PPP LCP Send Configuration Request
22:46:52, 09 Aug. (11606.720000) PPP LCP Send Configuration Request
22:46:49, 09 Aug. (11603.720000) PPP LCP Send Configuration Request
22:46:46, 09 Aug. (11600.720000) PPP LCP Send Configuration Request
22:46:43, 09 Aug. (11597.720000) PPP LCP Send Configuration Request
22:46:40, 09 Aug. (11594.720000) PPP LCP Send Configuration Request
22:46:37, 09 Aug. (11591.640000) ETHoA is up -​ VPI: 0, VCI:35
22:46:37, 09 Aug. (11591.640000) DSL is up
22:46:36, 09 Aug. (11590.570000) DSL noise margin: 9.10 dB upstream, 6.20 dB downstream
22:46:35, 09 Aug. (11590.310000) DSL line rate: 1134 Kbps upstream, 14334 Kbps downstream
22:46:09, 09 Aug. (11563.750000) CWMP: session closed due to error: No response
22:46:09, 09 Aug. (11563.730000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:46:09, 09 Aug. (11563.720000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:45:44, 09 Aug. (11538.730000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
22:45:43, 09 Aug. (11537.530000) DSL is down after 0 minutes uptime
22:45:43, 09 Aug. (11537.530000) ETHoA is down after 0 minutes uptime
22:45:42, 09 Aug. (11537.160000) PPPoA is down after 0 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
22:45:39, 09 Aug. (11534.330000) PPP LCP Send Termination Request [User request]
22:45:37, 09 Aug. (11531.900000) CWMP: session closed due to error: Could not resolve host
22:45:18, 09 Aug. (11512.560000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:45:18, 09 Aug. (11512.550000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:45:14, 09 Aug. (11508.910000) PPP IPCP Receive Configuration ACK
22:45:14, 09 Aug. (11508.790000) PPP IPCP Send Configuration ACK
22:45:14, 09 Aug. (11508.790000) PPP IPCP Receive Configuration Request
22:45:13, 09 Aug. (11508.320000) PPP IPCP Send Configuration Request
22:45:13, 09 Aug. (11508.320000) PPP IPCP Receive Configuration NAK
22:45:12, 09 Aug. (11507.150000) PPP IPCP Send Configuration ACK
22:45:12, 09 Aug. (11507.150000) PPP IPCP Receive Configuration Request
22:45:12, 09 Aug. (11506.440000) PPP IPCP Send Configuration Request
22:45:12, 09 Aug. (11506.440000) WAN operating mode is DSL
22:45:12, 09 Aug. (11506.440000) Last WAN operating mode was DSL
22:45:10, 09 Aug. (11504.960000) PPPoA is up -​ VPI: 0, VCI:38
22:45:10, 09 Aug. (11504.940000) CHAP authentication successful
22:45:10, 09 Aug. (11504.760000) CHAP Receive Challenge
22:45:10, 09 Aug. (11504.760000) Starting CHAP authentication with peer
22:45:10, 09 Aug. (11504.760000) PPP LCP Receive Configuration ACK
22:45:10, 09 Aug. (11504.710000) PPP LCP Send Configuration Request
22:45:10, 09 Aug. (11504.710000) PPP LCP Receive Configuration Reject
22:45:10, 09 Aug. (11504.710000) PPP LCP Send Configuration ACK
22:45:10, 09 Aug. (11504.710000) PPP LCP Receive Configuration Request
22:45:10, 09 Aug. (11504.610000) PPP LCP Send Configuration Request
22:45:07, 09 Aug. (11501.610000) PPP LCP Send Configuration Request
