Lozcs
Message 1 of 13
Replace Infinity Smart Hub
Hi,
I want to replace my Smart Hub, mainly to allow custom DNS over DHCP
Am I correct in thinking it's a VDSL, but also the socket on my master port is RJ11, from what I can see from routers I have looked at they are RJ45 - would these be compatible - Maybe the ASUS 88U?
12 REPLIES 12
Keith_Beddoe
Message 2 of 13
Re: Replace Infinity Smart Hub
Welcome to this user forum.
You need a VDSL modem/router with a RJ11 connection.
If all you want to do is to use a custom DNS, there are much simpler ways of doing it. All you need is to turn off the DHCP server on the BT Home hub, and use a different DHCP server connected to an Ethernet port on the home hub.
For example the TP Link WA801ND wireless access point can easily be configured that way. I use one to provide custom DNS (OpenDNS) to all devices. You also get extra wireless coverage.
See example settings below.
Lozcs
Message 3 of 13
I dont want to add another device on network for DHCP, would also like to upgrade router anyway (not had much joy with Smart Hub)
The face plate is currently RJ11 and BS 6132
Do I need a new Master socket? NTE5C? to use a modern VDSL modem? Or can I wire two wires from RJ11 to RJ45?
Liam_
Recognised Expert
Message 4 of 13
Just get a new VDSL capable modem/router, Asus, Billion, TP-Link etc and connect it with the cable that comes in the box.  Exactly the way the Hub 6 is connected just now.
Keith_Beddoe
Message 5 of 13
A third party VDSL modem/router would have an RJ11 plug on the end, so would plug directly into the phone line, just like the BT Home Hub 6. I cannot see what an RJ45 lead has to do with it?
There is no need to change the faceplate.
A popular VDSL modem/router is the TP-LINK TD-W9980
http://uk.tp-link.com/download/TD-W9980.html
Lozcs
Message 6 of 13
Just bought Asus DSL-AC68U
Liam_
Recognised Expert
Message 7 of 13
That should do fine.  Seems quit a few of them used by posters.
MorgaineD
Expert
Message 8 of 13
@Lozcs writes:
> "Just bought Asus DSL-AC68U"
Nice. 🙂  Please let us know if IPv6 pops straight up on it or not. 🙂
licquorice
Message 9 of 13
@Keith_Beddoe  FYI, the TD-W9980 is now obsolete, the VR600 and VR900 are the newer TP Link models.
Keith_Beddoe
Message 10 of 13
Thanks for that, I just noticed that on Amazon. Things move quickly these days compared with 1200 Baud modem days Smiley Wink
