Message 1 of 19
Replaced HH5 with Asus dsl-ac68u - dsl unstable issue
Hi all im experiencing an issue with an unstable line? here is the message im getting followed by an image "
Your DSL line appears to be unstable. DLA (Dynamic Line Adjustment) which enabled by default already adopted necessary changes and ensure stability"
asus
18 REPLIES 18
Message 2 of 19
Re: Replaced HH5 with Asus dsl-ac68u - dsl unstable issue
DLM is on all the time on your line and will make alterations to maintain a stable connection so it would appear to be doing its job.
See link
http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
Apart from the message you are getting is there any other symptoms of an unstable line.
Message 3 of 19
thanks for your reply and to your question no everything seems fine i just saw the message and thought something maybe wrong?
all the best
Message 4 of 19
Couple of points, VDSL should be 17A rather than 30A, and G.Inp should be enabled if you are connected to an Huawei cabinet.
Message 5 of 19
thanks for the information not sure what cabinet I'm connected to,
just a little additionally info I'm on BT infinity 2 fibre
Message 6 of 19
It won't hurt to enable it anyway, you may see an improvement in speed if connected to a Huawei cabinet, but will have no effect if connected to an ECI.
Message 7 of 19
Shall I disable the other?
Message 8 of 19
Disable what other? Or do you mean change 30A to 17A for VDSL profile, in which case, yes.
Message 9 of 19
disable G.vector (G.993.5)
Message 10 of 19
G.vector isn't available yet, so yes, disable that.
