I'm fed up with my HH5, after the firmware 'upgrade' in February wi-fi is almost unusable and BT want to charge me for a replacement HH5, no thanks, I don't want them to be able to 'upgrade' it again.
I don't have a seperate openreach modem, just the HH5 and Infinity 2, can anyone recommend a replacement VDSL modem router?
I've looked at the TP-Link TD-W9980 N600 and the Asus DSL-N66U, does anyone have any experience with either of these?
I personally prefer the look of the Asus, but it has mixed reviews, I also have devices that can make use of the slightly faster wifi offered by the Asus, I don't have anything that uses wireless AC so thats not a concern from any replacement router.
Thanks for the help.
there are users with bothe asus and tplink on forum and I'm sure they will post when they read yours
@licquorice has the TPlink and recommends it
As imj has said, perfectly happy with my TP Link, has been rock solid since before Christmas. I believe the problems with the Asus have been resolved by a firmware update since the poor reviews.
Thank you for your replies.
I know you can't answer in relation to the Asus, but I often log in to a machine at home via VNC, can this be done with the TP-Link?
Also, I sometimes disable items on the network, so children aren't on the internet late at night, that sort of thing, can that be done with the TP-Link aswell?
Finally, as both aren't crippled by BT, I assume I can go back to using opendns servers.
Thanks again
@edjonesy wrote:Thank you for your replies.
I have no reason to use VNC, but have no reason to believe there would be any problems.
Yes, but the way it works is a bit odd.
Definitely
Thanks again
Have a look at the user manual here http://uk.tp-link.com/resources/document/TD-W9980_1.0_User_Guide_1910010923.pdf
That's brilliant.
I've got to say, you're way more helpful than BT customer help, Thank you very much.
I'm using the Asus DSL-AC68U which is proving very reliable with the latest firmware. I'd guess that the DSL-N66U would also be reliable as my RT-N66U has been.
The TP-Link does seem to be a good option as it's liked here & is very affordable.
Thanks Tim.
Do you know if you can block devices at certain times and use VNC on the Asus? Please see one of my previous posts in the thread, I understand you may not know as they may be features you don't use.
I'm glad you find it reliable, that was the main complaint about the Asus I'm considering, but if the latest firmware is better, hooray.
With the AC68U (and I think most other Asus routers) there are parental controls to restrict specified devices to specific time slots so that'll do what you want.
About VNC I have no knowledge but can't see why it shouldn't work.
The reliablility I was referring to was for the AC68U , can't speak for the N66U I'm afraid. But there are recent firmware upgrades similar to the AC68U so my guess would be that the same improvement in reliability would be seen.
That's fair enough.
I understand you can only speak about the model you own, the negative reviews on Amazon seem to stop from about October 2014, and in the questions asked by prospective buyers and answered by existing owners people are using them with infinity and finding them much better than the HH5.
Thanks again.
