Message 1 of 5
Replacement hub 3
Hi
Just had a replacement hub 3 sent but it will not connect via ethernet to my desktop. It works via laptop on same cable also connects to desktop wireless. All worked fine on previous hub (before power surge blew it up) Anyone any idea what im doing wrong? Nothing has changed and i thought i could just swap the hub and all would be the same. The desktop just cant see the wired connection ?
Thanks for any help
Chris
4 REPLIES 4
Message 2 of 5
Re: Replacement hub 3
@snowmeow wrote:
Hi
Thanks for any help
Chris
I suspect that the power surge has damaged the Ethernet port on your desktop.
If its a separate network card, then they are cheap and easy to replace.
If its part of the motherboard, then there is nothing you can do about it apart from fit an internal network card if there is a spare PCI slot.
The alternative is a USB-Ethernet adapter.
Message 3 of 5
Thanks for the reply.
I have checked everything and the ethernet port shows as working in windows and all drivers are updated. i even reformatted the pc and still no change. i have bought a pci ethernet adapter so will see if this cures the problem when it arrives.
Thanks again
Chris
Message 4 of 5
The damage will be on the optical isolator within the network card hardware. Windows will not see this as it on the "hot" side of the hardware.
Windows can only check the software. There is normally an LED "link" light on the network card if it is working.
Message 5 of 5
Thank you for reply
I will see if the replacement pci card solves the issue. Sorry but can i pick your brains once again?  When i get the new pci card do i have to remove/uninstall the old one?.
Thanks again
Chris
