Message 1 of 7
Replacement modems
Hi
I think either my HomeHub or my Infinity router is on the blink. My speeds keep dropping down to around 2Mbps - I reboot both modems and I'm back up nearer to my 75Mbps. A few hours later, and I'm down to 2 again!! Frustrating.
Working on the assumption that these are faulty, (HomeHub about 4years old. Infinity about 18months) could I replace these 2 boxes with 1 single product, rather than the cluttered and ugly 2 box system that I currently have?
I have done some brief googling and indeed it seems possible (with a lot of tinkering of settings etc). Does anybody have any experience of doing this? Does this impact on BTWifi accessibility?
Thanks in advance.
Owen
6 REPLIES 6
Message 2 of 7
Re: Replacement modems
Do you have a home hub 3, and is it only slowing down on a wireless connection?
Message 3 of 7
Hi Keith.
Yes, it's a HomeHub3 and I only have WiFi devices, so can't comment on how wired speeds vary. Is this a known issue?
Message 4 of 7
Its a known issue, and BT will be rolling out a fix once the testing is complete.
See https://community.bt.com/t5/Other-Broadband-Queries/HH3-Infinity-Local-WiFi-Channel-fade/td-p/144629...
Meanwhile, you only need to restart the HH3, not the modem.
Message 5 of 7
Ok, thanks Keith. I guess that explains why my speed drops.
In regards to the 2nd part of my question, do you know if a single 3rd party router would result in me being unable to use BT WiFi? I hate how messy the 2 box system is!!
Message 6 of 7
Using an alternative router will not stop your access to other BT Wifi hotspots, but you would not be transmitting BT Wifi.
BT now use a HH5 on its own, for Infinity, but there are other alternatives.
See this post https://community.bt.com/t5/Other-Broadband-Queries/Alternative-to-HH5-WiFi-dropout-issues/m-p/14627...
and
Message 7 of 7
Perfect. Thanks again!!
