ChrisL1968
Message 11 of 16
Re: Replacing HH5 with TD-9980 - Openreach Fibre to Home modem
this is what my set up looks like
licquorice
Message 12 of 16
What version firmware are you running? Latest is
Firmware Version:0.6.0 1.13 v0021.0 Build 160125 Rel.52064n
ChrisL1968
Message 13 of 16
OK well its just suddenly started working, no idea why. Might have been the default gateway which I reset.
Thanks for your help people, I will mark this as fixed
licquorice
Message 14 of 16
Yes, I couldn't read the gateway from the screenshot, but it wasn't 'current connection'. I would still update the firmware if it is an older version (which I think it is as your menu options are different to mine).
N0STIE
Message 15 of 16
TD-W9980 doesn't have WAN port.
licquorice
Message 16 of 16
Really? Please explain how mine is working with a Huawei modem then. Please don't post incorrect information.
