Message 1 of 10
Replacing old-style master sockey with NTE5
I have an old-style (circa 1995) master socket which is getting very worn out, putting noise on my line and apparently causing DSL dropouts. I'd like to bring it into the 21st century and get an NTE5.
Now, I currently don't have a job and the £144 I've been told this task would incur is what I have to live on for about a week and a half. It would pain me to pay that amount of money for something I could get for a fiver online and probably be perfectly capable of fitting. But, I'm told I musn't touch these things or some day BT will throw the book at me.
Someone suggested an intermediate solution might be to get a freelance ex-BT engineer to fit it. But is *he* allowed to? Is there some kind of installation database that the new socket would then not be registered in, effectively voiding my right to get line faults fixed? Or if it was perfectly fitted would everyone just live happily ever after?
Can someone please explain my options and the precise implications of getting it wrong.
9 REPLIES 9
Message 2 of 10
Re: Replacing old-style master sockey with NTE5
there is no central data base that holds that detail and I'm sure no engineer would even know assuming a BT socket was used whether it was the home owner, ex engineer, electrician or openreach engineer had fitted the NTE5 as long as correctly fitted
I can't encourage you to change the socket on this forum but the choice is yours how you change it - just remember if you try and get it wrong and need openreach engineer that cost may be even greater the £144 you quoted
Distinguished Guru
Distinguished Guru
Message 3 of 10
It's not illegal to tamper with the master socket but it is against BT's term & conditions, so the most they would throw at you is a fat bill. Be careful about DIY though as you need a 30-bob tool and a screwdriver competency certificate.
Message 4 of 10
the NTE is the responsibility of BT to replace if it's faulty so unless you've damaged it then there shouldn't be a charge to replace it.....
Message 5 of 10
If there is nothing wrong with your existing master socket apart from it's old and your phone works ok then getting an engineer to fit an nte5 could be classed upgrade and you get charged £129.99. http://bt.custhelp.com/app/answers/detail/a_id/12439/c/
Message 6 of 10
Thanks for all the replies. Sorry, I would rate them but the white star doesn't seem to be working here. Noise on the line, due to the actual socket having become loose over time, is causing frequent DSL dropouts and difficulty in reconnecting. Would this count as it the socket unit being end-of-life and qualiify for a replacement?
Message 7 of 10
The OP says the master is causing the line to be noisy, although I'm unsure how he can be sure it's the socket unless he's removed it and clipped a phone directly onto the lead in pair???
Message 8 of 10
Because it's possible to vary - or lose if you're lucky - the noise by gently wiggling the phone jack around. I've tried it with an assortment of splitters which to my (admittedly uneducated in this respect) mind suggests the socket is wearing out.
Message 9 of 10
If your phone line is noisey hiss/crackle when making a call - try quiet line test- then report a phone fault to 151 and engineer will probably   replace the socket if that is causing the problem
Message 10 of 10
I have a similar problem though my line (https://community.bt.com/t5/Phones/Internal-wiring-fault-and-bt-visit/td-p/1388459) is fine on the test socket so I suspect they will want to charge.
