Message 1 of 2
Reporting fault fixed.
Can't see how to report fault fixed. It opened when I tested the line, but the problem was at my end.  Anyway if anyone from BT reads this, it's working fine and fualt can be closed.
1 REPLY 1
Message 2 of 2
Re: Reporting fault fixed.
Hi @rogercol
Thanks for your post and welcome back!
Sorry to see you had some problems recently.  I'm glad to see you've been able to pinpoint the issue.  No need to worry about the fault, it will close off itself 😊
Cheers,
Robbie
