Message 1 of 6
Request for interleaving to be turned off
I believe my connection to be very stable and for online gaming purposes i would like interleaving to be turned off. How would i go about getting this sorted out?
5 REPLIES 5
Message 2 of 6
Re: Request for interleaving to be turned off
the  mods can help but you need to post you adsl stats from your router first
Message 3 of 6
Are these the stats your after? Im new to this sorry 🙂
6. Data rate:20000 / 79995
7. Maximum data rate:32148 / 78069
8. Noise margin:15.5 / 11.8
9. Line attenuation:0.0 / 11.3
10. Signal attenuation:0.0 / 11.3
Message 4 of 6
you are on infinity/fibre and this board is for adsl
however the mods cannot help changing the latency only openreach and then only if they think it necessary.  The preferred stance is to maintain a stable conenction and it will change automatically
Message 5 of 6
Ooops - post deleted!
Distinguished Guru
Message 6 of 6
The post has been moved here
If not, I'll try again 🙂
