wiill
Message 11 of 28
Re: Requesting Interleaving turned off
that's fine - I'm just desperate to have it off
john46
Message 12 of 28
It could goo back on within a very short time all you can do is try
wiill
Message 13 of 28
Just to let you know I had a call a few days ago, letting me know they were going ahead with my request - which happened the same day. So far, so good!
Many thanks for everybody's help, and for the quick resolution!
DavidM
Moderator
Moderator
Message 14 of 28
Thanks for letting us know @wiill. Appreciate you taking time to do that. Post back if you have any other problems and we'll be happy to help.
Cheers
David
wiill
Message 15 of 28
hi guys
So unfortunately, looks like this hasn't worked out too well!
Ping has been great, and initially speed was almost as good as previously, sitting at 12meg rather than around 15 which it was on beforehand.
But line noise has since increased to about 21db and speed has dropped to around 3meg.
I can't paste router data as currently at work, but I assume this is entirely down to interleaving being turned off?
If this is the case, I assume it would be best to get this switched back on?
john46
Message 16 of 28
Why has my speed suddenly dropped?
ADSL connections (see notes about Infinity at the end), and the notes by RogerB
Changes in your connection speed are automatically managed by the exchange equipment, using a process called
Dynamic Line Management (DLM).
Its purpose it to give you the best speed possible, without introducing a lot of errors back into the BT network.
These errors impact on other users, and can slow their connection down, as your data packets have to keep being resent.
This is a continous process, but certain things can cause it to make drastic changes to your connection speed.
These can include the following:-
You could have also been recently moved from ADSL max to ADSL2+, this would mean that the line
would have to re-train again, and must be left undisturbed  for at least 10 days.
If you keep restarting or disconnecting your BT Home hub, then the exchange equipment will see this as a fault condition, and reduce your connection speed, in an attempt to stabilise your line.
You have recently had a fault on your line which has just been fixed.
Sometimes a single interruption to your line can cause this too, especially if it generates a large error burst.
The effect is that you get placed in a low banded speed profile, and you will notice that your downstream margin is high, usually over 15dB.
The lower the banded speed profile, the quicker it will recover, but it could take up to a month before the fullspeed is recovered.
If you want your speed to recover, then these are the steps you need to take.
DO NOT restart or disconnect the power to your BT Home Hub.
DO NOT disconnect your BT Home hub from your phone line.
Leave everything alone for at least 10 days, so that the exchange can record a stable connection.
During this time, the exchange may drop the connection, and re-establish a faster connection.
If you use the BT Speedtester, then do not restart the BT Home Hub, even if it tells you to.
If after 10 days your speed does not increase, then please return to your forum post.
showing  that you have 10 days of connection time, then the problem can be escalated.
Infinity connections
A similar process is applied to the connection between the Infinity cabinet, and the Openreach modem.
You cannot view that connection information, but the same thing applies, do not restart or disconnect the Openreach modem.
The BT home hub only acts as a router, and restarting it will not affect your physical connection speed to the cabinet.
Additional information by forum member RogerB
BT broadband is line adaptive, if you have a good line, you get good broadband , BUT consider this, you only get good broadband
from the outset, if you let the exchange "train" the connection, when it is new, simply because it has to try various methods of modulation.
And once it is running at full speed and set the MSR (maximum stable rate) provided you don't keep disconnecting the router, it will stay that way.
So two important things:  ALWAYS leave the router on, 24/7 and DO NOT impede the training process which can take up to 10 days.
The reasons are vaguely the same for both scenarios:  DLM trains the connection during setup, and DLM runs the connection in a similar but different mode once it's running.
And the most common issue apart from line faults in causing poor broadband is FREQUENT RESETS and DISCONNECTIONS of the router or hub, because if you interupt line management it will demote the line profile if done to excess, with often time consuming efforts and long waits to get it back.
BT don't punish users indiscriminently by making them wait for their broadband speed to come up, but the line management is in place  to DEFEND the network against bad and corrupted data, and if the exchange sees your line being reset too often it assumes a fault,
whereby your linespeed is demoted, and often profoundly so.
Also, because the exchange can't tell the difference between you messing around resetting all the time, and a real line fault, it assumes (using logic) the worst and demotes the line profile.
If you get a real line fault and the noise margin increases, the linespeed will decrease, it's normal, again it's a defence to help give you a service  allbeit a depleted one, and at the same time stop corrupted data getting back to the exchanges.
But unfortunatlely it's at this point when people in general start to become frustrated,  and guess what?
They then start to reset the router in an attempt to "repair" the connection. And in doing so, impede the line management from promoting the linespeed again. (providing any fault is or was fixed).
And to summarise, if the connection is left to run unimpeded, no excess resetting, and left to its own devices, it actually benefits from the good line
history that the exchange has accumulated for your connection, simply because the attention span by the line management is not so profound when it does bite the dust, for whatever reason.
So regardless of the opinions of some, switching off broadband routers is NOT a good idea, not if you want consistent broadband and a good line rate.
wiill
Message 17 of 28
Thanks John - I think the line has now been up since the 9th, as before this I think I did reset it after coming back from Holiday
I'll leave it be and post if anything changes
wiill
Message 18 of 28
Hi there
So I have left my connection untouched for the past 10 days and still have speed issues- what's the best next step?
john46
Message 19 of 28
can you please repost your hub stats
wiill
Message 20 of 28
hi John
The router hasn't been reset since around the 15th, but the latest stats are from the 25th:
03:57:10, 25 Feb.( 84.810000) DSL noise margin: 6.00 dB upstream, 21.60 dB downstream
03:57:09, 25 Feb.( 83.940000) DSL line rate: 1123 Kbps upstream, 4544 Kbps downstream
