Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
What is the best way to go about having interleaving turned off? I have tried speaking to support and they are very reluctant to do so - asking me strange questions such as who is suggesting that I do this etc..
I have always done this when I have lived in a house with BT broadband, and suddenly it's got a lot harder to do....
Solved! Go to Solution.
Welcome to this user forum.
Interleaving would have been applied to reduce the number of uncorrected errors on the line. Uncorrected errors reduce your download speed and place extra load on the BT Infrastructure, because information has to be resent.
Interleaving adds Forward Error Correction which provides a means to correct some errors at the receiving end.
Which BT Home hub are you using?
Thanks Keith - I've attached information from my router below - I hope this helps:
1. Product name: | BT Home Hub |
2. Serial number: | +068341+NQ33044367 |
3. Firmware version: | Software version 4.7.5.1.83.8.130.1.32 (Type A) Last updated 09/11/16 |
4. Board version: | BT Hub 4A |
5. ADSL uptime: | 3 days, 13:30:44 |
6. Bandwidth: | 1128 / 14357 |
7. Data sent/received: | 3.2 GB / 52.5 GB |
8. Broadband username: | bthomehub@btbroadband.com |
9. BT Wi-fi: | Yes |
10. 2.4 GHz Wireless network/SSID: | Obi Wlan Kenobi |
11. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
12. 2.4 GHz Wireless security: | WPA and WPA2 |
13. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
14. 5 GHz Wireless network/SSID: | Obi Wlan Kenobi 5Ghz |
15. 5 GHz Wireless connections: | Enabled (802.11 a/n (up to 300 Mb/s)) |
16. 5 GHz Wireless security: | WPA2 |
17. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
18. Firewall: | Default |
19. MAC Address: | cc:33:bb:b0:55:54 |
20. VPI/VCI: | 0 / 38 |
21. Modulation: | G.992.5 Annex A |
22. Latency type: | Interleaved |
23. Software variant: | - |
24. Boot loader: | - |
Thanks.
Unfortunately that does not give the information required.
Is there an additional option that gives information like noise margin?
Log in to the router and go to "Troubleshooting", choose "Event Log", and Category "WAN". You'll find something like this from the last time your line synched:
22:04:23, 09 Aug. ( 105.560000) DSL is up
22:04:22, 09 Aug. ( 104.640000) DSL noise margin: 5.90 dB upstream, 6.00 dB downstream
22:04:21, 09 Aug. ( 103.730000) DSL line rate: 1151 Kbps upstream, 14616 Kbps downstream
I have a feeling that the error statistics are not available on the home hub 4, so its not possible to see why interleaving may have been applied.
There is no real reason to want interleaving removed, and its likely to make your connection worse if there are errors on the line.
Hi Keith
I want to reduce my latency- it's something I've always done for the last 10 years if I've had BT, with no issue. It's even on BT's information as something that can be done - I found some information below:
14:34:02, 06 Jan. | (398942.860000) DSL noise margin: 6.00 dB upstream, 3.00 dB downstream |
14:34:01, 06 Jan. | (398941.950000) DSL line rate: 1152 Kbps upstream, 14357 Kbps downstream |
@wiill Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to help. You can find the link by clicking on my username.
Neil
Thanks Neil - will do this now
@wiill wrote:
Hi Keith
14:34:02, 06 Jan. (398942.860000) DSL noise margin: 6.00 dB upstream, 3.00 dB downstream 14:34:01, 06 Jan. (398941.950000) DSL line rate: 1152 Kbps upstream, 14357 Kbps downstream
As the noise margin is quite low, I would expect to see an increase in errors if inteleaving is removed. That is likely to make things worse unless you have good line conditions.
Excessive latency can be cause by using a wireless connection, instead of an Ethernet connection. Interleaving at maximum depth, only adds about 40ms, this is tiny compared with latency over the Internet as a whole.
See how it goes when its removed. You may initially see latency appear to get worse, as the CRC errors increase to a point where the home hub restarts. Over a period of time, DLM is likely to reduce the connection speed, thus increasing the noise margin to stabilise the line to reduce errors.
Hi Keith - I'm on a wired connection and spend a lot of time gaming, so the increased latency does affect me negatively quite badly.
Many thanks for your help - hopefully it will get removed and I can have a look at how things perform.
