Message 11 of 21
Re: Requesting a profile reset.
@hero wrote:
the bt speedtester will not load at all.
Have you got Java installed on your computer, it will not load without it?
Its not installed by default on Windows, you have to install it yourself.
hero
Message 12 of 21
hero
Message 13 of 21
Also just to add, i totally lost internet access on friday night(blue light would appear for around 20 seconds then go back to orange), via my homehub. Changed to netgear router and my connection has never droped, just painfully slow.
I have used the router im currently using with this connection before and not experienced problems in the past.
Message 14 of 21
could you please re run the speed test in an hour too see any possible changes
hero
Message 15 of 21
yeah ill get back to you
theriddlerz
Message 16 of 21
Just remember mate bt router will take 14 days to re-stable after been switched off so what there asking 4 show hubstats will take a bit to sort
Message 17 of 21
the riddlerz your post makes no sense a router does not take 14 days to stabilise after it is turned off
Message 18 of 21
Haha. This is a perfect example not to believe everything that's posted on a forum!
hero
Message 19 of 21
another speed test result.
Message 20 of 21
Hi I suggest you contact the forum mods they should be able to get your problem sorted for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
