TomH0927
Message 1 of 5
Reset Target SNR Margin
Hi all,
Recently my target SNR margin has increased from around 3dB to 13dB, resulting in me losing a large proportion of my download speed. I previously used to connected at around 7500-7600kbps downstream and the connection would be rock solid, mainting sync for weeks on end.
The target SNR jumped up a couple of weeks ago, and I am now consistently connecting at 4544kbps downstream, which gives a SNR of around 12-13dB. Weirdly, it's as though the DLM is forcing me to connect at a constant sync rate rather than a specific SNR margin. Anyway, the connection seems very stable and I have not lost sync once and I believe that since my line has coped well with lower SNR margins in the past that a reset wouldn't do any harm and should bring back some of the speed I previously had. I should point out I am on ADSL2+ too.
Line stats as follows:
ADSL Status
Parameters
DSP Firmware VersionA2pB025f.d22k
DMT StatusNo Defect
Operational ModeADSL2+
Upstream995
Downstream4544
SNR Margin(Upstream)6.0
SNR Margin(Downstream)12.9
Line Attenuation(Upstream)27.2
Line Attenuation(Downstream)48.5
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 8000
Max: Upstream rate = 996 Kbps, Downstream rate = 7248 Kbps
Path: 0, Upstream rate = 995 Kbps, Downstream rate = 4544 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 12.9 6.0
Attn(dB): 48.5 27.2
Pwr(dBm): 0.0 13.0
ADSL2 framing
MSGc: 59 12
B: 142 30
M: 1 1
T: 1 4
R: 0 0
S: 1.0000 0.9880
L: 1144 251
😧 1 1
Counters
SF: 15568720 75145
SFErr: 1928 658
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 1315 567
OCD: 47 0
LCD: 0 0
Total Cells: 2711309009 593164905
Data Cells: 282083876 25894710
Drop Cells: 27214
Bit Errors: 0 37431
ES: 3120 817
SES: 6 0
UAS: 240 240
AS: 252994
INP: 0.00 0.00
PER: 16.25 17.78
delay: 0.25 0.24
OR: 32.00 8.09
Bitswap: 586 0
Total time = 1 days 1 hours 39 min 24 sec
FEC: 0 0
CRC: 968 0
ES: 312 817
SES: 6 0
UAS: 240 240
LOS: 0 0
LOF: 0 0
Latest 15 minutes time = 9 min 24 sec
FEC: 0 0
CRC: 1 0
ES:   2 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 4 0
ES: 4 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 1 hours 39 min 24 sec
FEC: 0 0
CRC: 15 0
ES:   22 5
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 0 0
CRC: 152 0
ES:  297 152
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Since Link time = 2 days 22 hours 16 min 34 sec
FEC: 0 0
CRC: 310 158
ES:  501 252
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Are the mods able to request a reset of the target SNR or to restart the line training? I am connected to the master socket with a filtered faceplate so have eliminated all potential wiring interference issues.
4 REPLIES 4
imjolly
Message 2 of 5
Re: Reset Target SNR Margin
to get noise margin to jump to 13db there must have been/still is a noise problem on your line.  were you getting drops in connection or were your resetting to get speed back or both?
TomH0927
Message 3 of 5
No drops in connection, I restarted the router a couple of times to try and get the speed back which I guess may have made things worse possibly?
imjolly
Message 4 of 5
restarting the router a few time will certainly not helped get your noise margin down and in fact may result in it increasing.  the noise margin should reduce automatically but you need a stable connection for 7/10 days - not shown that time looking at stats
john46
Message 5 of 5
your attenuation suggests a maximum speed of 5.9mb you must ensure a stable connection for the next 7/10 days the connection time must be shown on the routers stats not just the number of days you have the router turned on
