currie728
Message 1 of 31
Resetting my Noise Margin after recent fault please
Hi Im new to the forum but been a customer to bt for about 3 years..
been doing some research and i have had a fault in recent with phone crackling and it would cause the router to re-boot itself now and again we would restart it because its slow but its best to leave it constantly on ok once fixed i spotted my noise margin is high soo...
can i report back when i have maintained a stable connection time in the routers gateway and have it reset i will post my stats.
30 REPLIES 30
Message 2 of 31
Re: Resetting my Noise Margin after recent fault please
 We need to see 3 days + stable connection before a reset could be carried out
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
currie728
Message 3 of 31
We have Sky Multiroom one of which is in my dads room and he turns the sky box off when he goes to bed i have no idea why the box is connected to the phone line would this affect the line becoming unstable
Message 4 of 31
part of the multiroom contract is that boxes must be connected to phone line - to check they are being used on same phone line/same property.  you can disconnect after contract expires.  sky box in your father's room must have a filter connected to the phone line unless you have a filtered master socket faceplate
currie728
Message 5 of 31
does everything to the phone line have to be on 24/7 just the router to obtain a stable line how do i get my speed increased
ip/profile banded?
Message 6 of 31
just your router should be left connected 24/7 for best connection - recommended by BT but there are many on the forum who switch router off at night and on in morning without any problems
currie728
Message 7 of 31
ok when the router has kept connected for the 3+ days that will indicate a stable line therefore hit the disconnect button instead of restarting hopefully that will show a rise in the connection speed??
Message 8 of 31
No maintain the stable connection once the 3 days + has been reached we can give you a link to the forum mods if needed to reset your noise margin if it has not reset automatically resetting your hub is the worse thing you can do you need a stable connection at all times
currie728
Message 9 of 31
should i click the disconnect in my home hub setting when the 3+ days have past and do NOT reset or restart can i comfirm please
Message 10 of 31
no leave completely alone your connection must remain stable with NO RESTARTS
