currie728
Message 11 of 31
Re: Resetting my Noise Margin after recent fault please
how will we know willl the stats update without a restart or disconnection
Message 12 of 31
if the noise margin changes automatically the hub will restart automatically if there are no changes then you will need the mods assistance to reset manually but 3 days stable first as they need to see 3 days before they will reset it
Guru
Message 13 of 31
Only partially true .... noise margins can and do change all day and night without hubs restarting.
They would only restart when a pulse check from DLM checks the line parameters to check sync/error rate/INP
and sees that a forced auto reset by DLM benefits a "significant" linespeed upgrade.
The only other time is during the 10day line training for the purpose of establishing the MSR.
Best practice is to monitor SNRm coming down .... and force a reset in daylight everytime you gain 2db.
But not at night, as margin erodes.
MSANs run fulltime line management on all connections, plus one pulse once every 24 hours to "check things over".
If the line has problems, (banding) or high noise margin, it will pulse more, and give the line "attention"
but not necessarily a reset.
currie728
Message 14 of 31
Hello users and forum mods.. morning i can report so far so good my apolgies if the size of the image is small.
Image and video hosting by TinyPic
Message 15 of 31
Hi just keep posting the stats then if needed we can take it further if needed
currie728
Message 16 of 31
Oh Dear it decided to drop out here are the stats.. however a very fraction noise margin have reduced and an increase in upload314401i.png
 Event Log
This page summarises all the recent events that have been recorded on your BT Home Hub.
You can filter the events to show items related to a specific category.
Category  All
0
Other
780
BT OpenWifi
1020
DHCP
230
DSL Home
220
Dynamic DNS
240
Firewall
200
PPP
610
System Up/Down
740
Time of Day
120
Web-Based Management
440
Wireless
410
Recorded events
Time and date Message
08:41:56, 13 Nov. (13016.630000) Admin login successful by 192.168.1.68 on HTTP
08:39:06, 13 Nov. (12846.910000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
08:36:43, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 54 Mbps
08:33:07, 13 Nov. (12487.520000) OpenWiFi_1 IPSec connection is up
08:33:05, 13 Nov. (12486.150000) OpenWiFi_1 IPSec connection is down
08:31:54, 13 Nov. Host 28:e7:cf:03:34:61 connected to SSID 'BTHub3-FMS2' at 24 Mbps
08:31:54, 13 Nov. (12415.050000) Lease for IP 192.168.1.67 renewed by host Unknown-28-e7-cf-03-34-61 (MAC 28:e7:cf:03:34:61). Lease duration: 1440 min
08:31:54, 13 Nov. (12415.040000) Lease requested
08:25:40, 13 Nov. (12040.540000) Admin login successful by 192.168.1.68 on HTTP
08:25:36, 13 Nov. (12037.270000) New GUI session from IP 192.168.1.68
08:25:36, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 54 Mbps
08:19:26, 13 Nov. (11666.630000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
08:10:42, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 54 Mbps
08:10:30, 13 Nov. 3 consecutive beacons have not been transmitted
08:10:28, 13 Nov. (11128.880000) OpenWiFi_1 IPSec connection is up
08:08:25, 13 Nov. (11005.900000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
07:52:55, 13 Nov. (10075.880000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
07:52:38, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 54 Mbps
07:50:42, 13 Nov. Host 28:e7:cf:03:34:61 connected to SSID 'BTHub3-FMS2' at 54 Mbps
07:50:41, 13 Nov. Host 28:e7:cf:03:34:61 connected to SSID 'BTHub3-FMS2' at 48 Mbps
07:50:40, 13 Nov. Host 28:e7:cf:03:34:61 connected to SSID 'BTHub3-FMS2' at 24 Mbps
07:50:40, 13 Nov. ( 9940.730000) Lease for IP 192.168.1.67 renewed by host Unknown-28-e7-cf-03-34-61 (MAC 28:e7:cf:03:34:61). Lease duration: 1440 min
07:50:40, 13 Nov. ( 9940.720000) Lease requested
07:49:07, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 54 Mbps
07:43:13, 13 Nov. Host 28:e7:cf:03:34:61 connected to SSID 'BTHub3-FMS2' at 24 Mbps
07:43:12, 13 Nov. ( 9493.410000) Lease for IP 192.168.1.67 renewed by host Unknown-28-e7-cf-03-34-61 (MAC 28:e7:cf:03:34:61). Lease duration: 1440 min
07:43:12, 13 Nov. ( 9493.400000) Lease requested
07:34:42, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 24 Mbps
07:30:55, 13 Nov. ( 8755.750000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
07:12:15, 13 Nov. ( 7635.730000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
06:59:43, 13 Nov. ( 6883.720000) Lease for IP 192.168.1.67 renewed by host Unknown-28-e7-cf-03-34-61 (MAC 28:e7:cf:03:34:61). Lease duration: 1440 min
06:59:43, 13 Nov. ( 6883.720000) Lease requested
06:59:43, 13 Nov. Host 28:e7:cf:03:34:61 connected to SSID 'BTHub3-FMS2' at 24 Mbps
06:59:25, 13 Nov. ( 6865.740000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
06:59:10, 13 Nov. Host 28:e7:cf:03:34:61 connected to SSID 'BTHub3-FMS2' at 24 Mbps
06:50:55, 13 Nov. ( 6355.740000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
06:49:05, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 48 Mbps
06:39:45, 13 Nov. ( 5685.730000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
06:19:55, 13 Nov. ( 4495.580000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
06:19:05, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 48 Mbps
05:49:15, 13 Nov. ( 2655.470000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
05:49:00, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 54 Mbps
05:47:15, 13 Nov. ( 2535.460000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
05:33:45, 13 Nov. ( 1725.450000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
05:24:46, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 48 Mbps
05:23:45, 13 Nov. ( 1125.440000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
05:18:34, 13 Nov. ( 815.330000) Host Unknown-00-24-8d-03-6d-8b (MAC 00:24:8d:03:6d:8b) using IP 192.168.1.1 detected on interface eth0, port -1
05:18:12, 13 Nov. Host d4:4b:5e:74:36:6a connected to SSID 'BTHub3-FMS2' at 72 Mbps
05:18:11, 13 Nov. ( 791.790000) Lease for IP 192.168.1.64 renewed by host PS Vita(d4-4b-5e-74-36-6a) (MAC d4:4b:5e:74:36:6a). Lease duration: 1440 min
05:18:11, 13 Nov. ( 791.780000) Lease requested
05:18:11, 13 Nov. Host d4:4b:5e:74:36:6a connected to SSID 'BTHub3-FMS2' at 52 Mbps
05:17:51, 13 Nov. ( 772.210000) Lease for IP 192.168.1.64 renewed by host PS Vita(d4-4b-5e-74-36-6a) (MAC d4:4b:5e:74:36:6a). Lease duration: 1440 min
05:17:51, 13 Nov. ( 772.200000) Lease requested
05:17:51, 13 Nov. Host d4:4b:5e:74:36:6a connected to SSID 'BTHub3-FMS2' at 24 Mbps
05:07:12, 13 Nov. ( 132.510000) Server URL: https://pbthdm.bt.motive.com; Connecting as user: ACS username
05:07:00, 13 Nov. Host 00:22:5f:9a:b4:53 connected to SSID 'BTHub3-FMS2' at 18 Mbps
05:06:59, 13 Nov. ( 120.340000) Lease for IP 192.168.1.68 renewed by host Chris-PC (MAC 00:22:5f:9a:b4:53). Lease duration: 1440 min
05:06:59, 13 Nov. ( 120.330000) Lease requested
05:06:40, 13 Nov. ( 100.430000) Time synchronized with server 213.123.26.170
05:06:40, 13 Nov. ( 99.900000) Requesting time from server 213.123.26.170
05:06:39, 13 Nov. 3 consecutive beacons have not been transmitted
05:06:34, 13 Nov. ( 94.600000) Server URL: https://pbthdm.bt.motive.com; Connecting as user: ACS username
05:06:30, 13 Nov. ( 90.020000) WAN operating mode is DSL
05:06:30, 13 Nov. ( 90.020000) Last WAN operating mode was DSL
05:06:28, 13 Nov. ( 88.550000) PPPoA is up
05:06:28, 13 Nov. ( 87.980000) CHAP authentication successful
05:06:28, 13 Nov. ( 87.900000) Starting CHAP authentication with peer
05:06:26, 13 Nov. ( 86.260000) New GUI session from IP 192.168.1.1
05:06:26, 13 Nov. ( 86.190000) New GUI session from IP 192.168.1.1
05:06:26, 13 Nov. ( 86.120000) New GUI session from IP 192.168.1.1
05:06:25, 13 Nov. ( 85.640000) DSL is up
05:06:23, 13 Nov. ( 83.530000) DSL noise margin: 8.90 dB upstream, 18.00 dB downstream
05:06:22, 13 Nov. ( 82.040000) DSL line rate: 1067 Kbps upstream, 1150 Kbps downstream
05:06:20, 13 Nov. ( 80.250000) New GUI session from IP 192.168.1.1
05:06:20, 13 Nov. ( 80.180000) New GUI session from IP 192.168.1.1
05:06:20, 13 Nov. ( 80.110000) New GUI session from IP 192.168.1.1
05:06:18, 13 Nov. ( 78.020000) New GUI session from IP 192.168.1.65
05:06:15, 13 Nov. ( 75.180000) New GUI session from IP 192.168.1.65
05:06:14, 13 Nov. ( 74.680000) New GUI session from IP 192.168.1.65
05:06:14, 13 Nov. ( 74.260000) New GUI session from IP 192.168.1.1
05:06:14, 13 Nov. ( 74.210000) New GUI session from IP 192.168.1.65
05:06:14, 13 Nov. ( 74.180000) New GUI session from IP 192.168.1.1
05:06:14, 13 Nov. ( 74.110000) New GUI session from IP 192.168.1.1
05:06:13, 13 Nov. ( 73.670000) New GUI session from IP 192.168.1.65
05:06:13, 13 Nov. ( 73.560000) New GUI session from IP 192.168.1.65
05:06:13, 13 Nov. ( 73.160000) New GUI session from IP 192.168.1.65
05:06:05, 13 Nov. ( 64.950000) New GUI session from IP 192.168.1.65
05:06:04, 13 Nov. ( 64.790000) New GUI session from IP 192.168.1.65
05:06:02, 13 Nov. ( 62.020000) New GUI session from IP 192.168.1.1
05:06:02, 13 Nov. ( 61.970000) Server URL: https://pbthdm.bt.motive.com; Connecting as user: ACS username
05:06:01, 13 Nov. ( 61.640000) New GUI session from IP 192.168.1.1
05:06:01, 13 Nov. ( 61.580000) New GUI session from IP 192.168.1.1
05:06:01, 13 Nov. ( 61.510000) New GUI session from IP 192.168.1.1
05:06:01, 13 Nov. ( 61.450000) New GUI session from IP 192.168.1.1
05:06:01, 13 Nov. ( 61.400000) New GUI session from IP 192.168.1.65
05:06:01, 13 Nov. ( 61.370000) New GUI session from IP 192.168.1.1
05:06:01, 13 Nov. ( 61.340000) New GUI session from IP 192.168.1.65
05:06:01, 13 Nov. ( 61.300000) New GUI session from IP 192.168.1.65
05:06:01, 13 Nov. ( 61.260000) New GUI session from IP 192.168.1.65
05:06:01, 13 Nov. ( 61.200000) New GUI session from IP 192.168.1.1
 Unknown-00-24-8d-03-6d-8b is a PS3 we have 2 and set it up with each having a static ip
Message 17 of 31
Just leave things alone for now
currie728
Message 18 of 31
Hi the router restarted and bang the speed bumped up incredible
Message 19 of 31
Hi that is looking better and once you noise margin drops to its default of 6dB you should get an further increase in speed just let the connection settle on its own now
currie728
Message 20 of 31
Hi again.. 🙂
what will need reseting manually by a mod after the 3 days of having a stable line is it now ok at 6db default also how can i get the latency type from Interleaved to fast please
