Message 21 of 31
Re: Resetting my Noise Margin after recent fault please
the mods can make the change but going to fast can make your connection less stable.  if noise margin now down to 6db can you post new stats including the errors
currie728
Message 22 of 31
updated stats
Message 23 of 31
no change in stats yet
Guru
Message 24 of 31
You should have gone to specsavers John.
Clearly ..... you don't see what I see.
Furthermore, I'd recommend against changing to fastpath .... for the moment anyhow.
Message 25 of 31
clearly i should have I had only noted the change in up margin and had missed the down speed increase
Guru
Message 26 of 31
I was actually refering to the bit error rate versus timescale, and it's relationship with noise margin levels.
And why I said .... fastpath on that connection is not a good idea .... for the time being.
(it's what stats are for ...)    🙂
Message 27 of 31
even with the high noise margin interleave is working hard shown by the number of errors so I would stay with interleaved and concentrate first on getting your noise margin down to 6 and if line is still ok then nearer 3 - but 6db first.  this will increase your speed far more than switch to fast
currie728
Message 28 of 31
lol funny hahah but to change to a fastpath it is in your power to do that..
sorry .. im misunderstanding i have to get my (UP) noise margin to a default of 6db first?
what about the 3 days to have a stable line is it expired or..
Message 29 of 31
your current noise margin is 15.3db and you need to try and get it down to normal of 6db which will result in an increase in your connection speed.  Many lines now work on a margin of 3db and that would increase your connection speed yet again but many find the drop to 3db causes more errors and slows down the download speed so end up going back to 6db.
interleaved looks best for your line just now but that's not to say with improvement that you cannot eventually go to fast
any change from interleave to fast would need you to contact the mods
currie728
Message 30 of 31
just to update the noise margin has dropped now at 13.5 dB
