Restoring lost contacts from iPhone is not so easy, and the iPhone Data Recovery can only recover lost contacts from iPhone directly, fo rother vewrsions, you need to made backup before.
1, select recover from iTunes backup files mode
2. Select the backup files to scan for the lost photos
3. Preview and recover lost photos from iTunes backup
Hi Shayie, just in case you are waiting for a reply from the OP, this post is over a year old and the OP has not been back to the forum since then but I'm sure your answer may be able to help others.
@Shayie wrote:Restoring lost contacts from iPhone is not so easy, and the iPhone Data Recovery can only recover lost contacts from iPhone directly, fo rother vewrsions, you need to made backup before.
Hello Shayie, this post is over a year old. But your way work for me, now. Thanks.
Fonepaw iPhone Data Recovery (Mac) can help you recover all lost contacts on iPhone, iPad and iPod touch, including the iPhone 6/5S/5/4S/4 and iOS 8/ iOS 9.This iPhone data recovery provides you three ways to recover contacts from iPhone, iTunes or iCloud backup file.
You can clearly preview all lost or deleted contacts before recovery, and selectively recover whatever only what you want—something you can't do with iTunes!
If you didn't backup your iOS files to iTunes or iCloud or you failed to restore from your backup files, then you can try some iOS recovery tool to get back data from the iDevice directly. See this guide: how to recover deleted contacts from iphone
Restoring contacts and calendars on iOS devices after switching to BT Mail is not easy. Of course if we have taken backup before, we can restore from backup. If not, we need use iOS Data Recovery program to help us do the data restoring.
