jimbo59
Message 1 of 13
Result of speed test
I Just did this test and this is result anyone advise please Im new to thisSmiley Sad
Test1 comprises of Best Effort Test: -provides background information.
Download  Speed
113 Kbps
0 Kbps250 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 113 Kbps
 For your connection, the acceptable range of speeds is 50-250 Kbps.
 Additional Information:
 Your DSL Connection Rate :512 Kbps(DOWN-STREAM), 96 Kbps(UP-STREAM)
 IP Profile for your line is - 135 Kbps
Tags (2)
12 REPLIES 12
Message 2 of 13
Re: Result of speed test
can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1)
are you connected to the master or test socket or somewhere else
Someone may then be able to offer assistance
jimbo59
Message 3 of 13
ADSL line status<script type="text/javascript"></script>
Connection information<script type="text/javascript"></script>
Line stateConnected
Connection time0 days, 0:40:27
Downstream512 Kbps
Upstream96 Kbps
ADSL settings<script type="text/javascript"></script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.1 dB / 6.0 dB
Line attenuation (Down/Up)49.0 dB / 29.0 dB
Output power (Down/Up)15.1 dBm / 10.3 dBm
Loss of Framing (Local)11
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)5360 / 5
CRC Errors (Down/Up)40 / 2147480000
HEC Errors (Down/Up)nil / 4
Error Seconds (Local)130
Message 4 of 13
are you connected to the master or test socket or somewhere else?
have you tried the quiet line test  dial 17070 option 2  should hear nothing - best done with a corded phone
do you have extension sockets in your home?
jimbo59
Message 5 of 13
I am conected to master and no extentions tryed quiet line but i hear the home hub kick in
Message 6 of 13
are you having connection problems with the hub resetting on it's own or are you resetting the hub in the hope of getting a better connection?
have you tried replacing the filter as they do not last forever?
jimbo59
Message 7 of 13
Replaced fillters, not resetting now have a person from BT comming saturday as they say there a fault from pole to house this with other issues been going on from day one
hopefully be all sorted then will let you know
Message 8 of 13
no point trying anything until engineer been on saturday and hopefully fix your connection problem
jimbo59
Message 9 of 13
Ok enginneer called to day was with me about 2 hours cleaned the line no crackling or modem noise and dont have to leave the phone off hook to connect to BB but still a problem he says looks like service restricted he getting reading of 0.5 mb how will i find if service is restricted
jimbo59
Message 10 of 13
oh heres adsl states now
ADSL line status
Line state Connected
Connection time 0 days, 0:50:46
Downstream 1,024 Kbps
Upstream 352 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Fast
Noise margin (Down/Up) 5.9 dB / 6.0 dB
Line attenuation (Down/Up) 47.0 dB / 26.0 dB
Output power (Down/Up) 17.3 dBm / 11.9 dBm
Loss of Framing (Local) 28
Loss of Signal (Local) 3
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 0
CRC Errors (Down/Up) 496 / 2147480000
HEC Errors (Down/Up) nil / 73
Error Seconds (Local) 1
